3 Ways You Can Help the FliteTest Podcast!
We just might play it on the next show! If you don't have a computer microphone, you can also download the SpeakPipe app for iPhone or iPad and leave a message that way. Remember to leave your name, where you are from and your question/discussion topic in under a minute to have the best chance of being played on the show!
Hang out with us around the web!
Facebook: facebook.com/flitetest
Google+: google.com/+FliteTestHQ
Twitter: twitter.com/flitetest
Vine: @FliteTest
FliteTest Instagram: @flitetest
Josh's Instagram: @flitetestjb
Alex's Instagram: @zvada
Austin's Instagram: @austinfurey
Have a thought about the show?
Rate us in iTunes! It helps us out a lot. :)
flitetest.com/itunes
DX6i and AS3X on the SUKHOI 29mm & Super Cub S.
Regarding Tx setup for the Sukhoi.
The Super Cub instructions MUST be wrong. It IS the Flaps switch that controls Panic recovery. However, the set up DID NOT give me 3 modes on the Super Cub. The solution that has worked for me is: the settings in the instruction booklet do not cause Channel 5 to reach zero and thus EXPERIENCED MODE is NOT available. The fix that worked for me, adjusting it until it looked right in MONITOR was: SubTrim: Gear up 25, and, Mix 'Up' +125%. All 3 modes and Panic now work perfectly and the model is BRILLIANT. Flew it today in winds gusting to 16mph with no problems at all and virtually vertical landings, just BRILLIANT.
The Sukhoi 29mm instructions are:
1. Go to the SETUP LIST MENU
2. Set MODELTYPE: ACRO
3. Set REVERSE: Gear Channel
4. Go to ADJUST LIST MENU
5. Set TRAVEL ADJ: Gear/Fmode (0) ↑100%; Gear/Fmode ↓40%
6. Set FLAPS: Norm ↑100; LAND ↓100
7. Set MIX 1: ACT; Gear >Gear ACT, RATE D 0%; U + 100%, SW MIX, TRIM INH
Resulting in: The Gear and Mix switches operate the 3 SAFE modes Gear 0; Mix 0 = StagilityTM Mode Gear 1; Mix 0 = AS3X 3D Mode Gear 1; Mix 1 = AS3X Precision Mode
The FLAP switch operates Panic Recovery: Position 0=Off, Position 1=On. (not a momentary switch)
Now compare that with the Super Cub instructions:
Super Cub S
5. Set TRAVEL ADJ: Gear/Fmode (0) ↑100%; Gear/Fmode (1) ↓40%
6. Set FLAPS: Norm 100; LAND 100
7. Set MIX 1: ACT; Gear > Gear ACT, RATE D 0%; U + 100%, SW MIX, TRIM INH
Resulting in:
The Gear and Mix switches operate the 3 SAFE modes Gear 0; Mix 0 = Beginner Mode ; Gear 1, Mix 0 = Intermediate Mode ; Gear 1, Mix 1 = Advanced Mode
The Trainer switch operates Panic Recovery.
You can see what I had to do to get the 9X and orange module to work.
http://forum.flitetest.com/showthread.php?12615-Andre-s-Sukhoi-SU-29MM
I think it's great that you can be so proud of your box. I destroy my boxes as quickly as possible because I feel that they are more likely to upset the wife, they are SO big.
Hey Chris, speaking of the Mule, check this out: http://parkflyerplastics.com/cart/index.php?main_page=product_info&cPath=28_50&products_id=706
Here is the link to mine.
http://forum.flitetest.com/showthread.php?12629-Andre-s-Durafly-SkyMule
Just wanted to say thanks for all the good info. I am definitely adding the pico qx to the Christmas list for my wife to get me.
I bought my brother-in-law the proto x when he was in town this past week and he loves it. After researching, we found out that the Hubsan x4 radio works for the proto x, enabling the flip functionality. Check it out if you haven't already.
Thanks again,
Brad.
At the moment it's out of stock, but who knows, they might be getting more in.
Flying Gangnam Style!!
http://www.dx.com/p/2-5-ch-radio-control-r-c-flying-psy-gangnam-style-helicopter-with-colorful-light-blue-black-193055
