This is my first scratch build ever. I am apologizing in advance for how horrible this article may be. This mini wing is built from the 24" plans with every dimension divided by two. The parts were rather simple. Its all dollar tree foam board. The receiver I used is from my MCX heli that I no longer fly, but a regular UM board will work. The motor is from the UM T-28, which is the exact same motor as the UM P-51. The control surface horns are standard UM control horns and were actually salvaged from an earlier wreck. I still need to apply some velcro for the battery but for preliminary flight purposes I just taped the battery to the bottom and it worked just fine. The push rods are what gave me the most trouble. If you build this make sure you have the length exactly right or it will be a bear to get it to fly level. The body itself uses a KFM Airfoil covered with clear packing tape. The hinges are also clear packing tape. I am more than happy to answer any questions you have about this build. Like I said this is my first article so I'm not exactly sure what all I need to put in it.
Here are the plans all credit goes to forlack from RCgroups.com
http://www.rcgroups.com/forums/showthread.php?t=1252282
-Low, Fast an Hot.
Thanks for the build article!
I can't quiet tell from the photo, but ss that a 5-in-1 board from a micro heli (like the HK-190) that you have used for electronics/servos?
Item: EFLH1065 at horizonhobby.com. I could be wrong but i think when you switch it over from heli to elevon it cancels the gyro. However i would recommend the UM t-28, UM P-51, or possibly the J-3 board ( if it will handle elevon mixing) just to be on the safe side. I recently switched mine out to the UM T-28 board. expo set at 70, 30.
