Hi folks,
Here my Ultra Micro FPV Plug and Play!
Specifications
Input power: 2.2-5V
Power consumption: 285mA @ 5V
Frequency: 5.8GHz (8 Channels with Pushbutton selection)
Output power: 10-100mW (Adjustable with variable resistor)
Weight: 3.7 grams
Part lists
1x Pololu - 5V Step-Up Voltage Regulator U3V12F5 (3,95 US$)
1x FPVHobby - 5.8 GHz AVTx (39 US$)
1x FPVHobby - 1 gram Pal Camera (54 US$)
Flight test! with headshot at end. Video transmitter power set to 10mW.
Could you please tell me or show me how you mounted the cam and the regulator on the sender?
Thank you for sharing!
Greetings from Switzerland
It is not only for indoor, a FPVer from Finland, got 575 meters range with same setup. Interesting...
http://vimeo.com/112842522
(my nano qx control is getting interferance at 15 meters or behind a wall/room)
i am using an orange rx in my 9x transmitter.
please help.
