Some details about the camera:
808 #16V2 Keychian Micro Camera has added TV output (video only)
They also offer different lens options and other accessories separately, please check there ebay store.
My camera came with the D lens a 120 degrees view. You will find more information about this lens option on Tom Frank's #16 thread.
Here is a link to buy the new V2 Camera.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=290750966551
This video goes into set up options to change things in the camera settings: http://www.youtube.com/watch?v=sSg-8ktRq4UPackage includes:
1X 808 #16 HD Car key Micro camera Wide Angle lens (Lens D). It's 120 degrees.
1X USB cable
1 pair Velcro
1 pair of Video Output cable
Specs:
1/4" CMOS WXGA HD Sensor / H.264/AVC1 DSP / 512M DDR2
Rechargeable LIPO Battery (250mah), with Battery Charger Manage IC
Video: 720P HD H.264/AVC1 video codec, 1280 x 720 30fps .mov
Photo: JPG 1280*960 (no degrading by upsizing to interpolated "5 megapixel" size)
microSD card slot, supports up to 32GB (memory card not included), suggest using Class 4 or above.
USB2.0
Size: 50mm (L) x 32mm (W) x13mm (H)
Weight: approx 17g
Can be used as a DVR, a camera, a webcam, a removable USB drive.
What's special about 808 #16 V2 camera?
1. A connector added for the internal battery, making it changeable by users who don't like soldering. You don't have to throw your camera away when the battery dies. You just need a new battery and change it!
2. A connector added to the lens/sensor module, make it possible to replace or upgrade it when new module's are available.
3. New Lens and totally new circuit board design. You will see below improvements in video:
- Overall sharpness: improved
- White balance control / color shifting issue: improved
- Saturation / and contrast boost issue: colors look much more natural now
- Darker corner/edge vignetting issue: improved
4. Low battery buzzing artifact in video -Gone!
5. You only need one Standard USB Data cable for charging and data exchange with your computer.
6. It supports audio volume control, and you can even get it mute to save battery and helps to increase the recording time when the audio is not needed, it can be set by TXT config tool.
7. It supports optional Loop Recording, it can be set by TXT config tool.
8. You can set the date and time (white much smaller on the lower left corner), and toggle the date/time stamp on or off, by TXT config tool.
9. If you don't want 720P recording to save battery and memory card capacity, now you can toggle video output frame size from 1280x720 30fps (default), to 848x480 30fps, or 640x480 30fps.
10. AVI output: we also have another firmware option available which will output .AVI file format, using the same H.264 codec, and it offers seamless recording (there is no lost video between clips). If you need it, please send a message to us, and we will send it to you by email.
Please Subscribe, Like & Comment
Build, Fly, Crash, Repair, Repeat.
My Gear:
FPV Gear:
www.videoaerialsystems.com
www.readymaderc.com
Video:
808 #16 Keychain Camera with modded lens.
808 #16 V2 D Lens
Planes: Ibcrazy Spector
FPV40 Scratch Build Wing from Dollar Tree Foam
Flight Test Nut Ball
Radio: Futaba T6EXA Radio
Spectrum Dx6i
Receiver: Coronal RP6D1 / RP8D1
Ground Station:
1.2 Ghz Transmitter and receiver for video
Helical and Cross Hair Antenna
Vuzix Wrap 920 Goggles
7" LCD
Great Stuff on YouTube:
http://www.youtube.com/user/flitetest
http://flitetest.com
http://www.youtube.com/user/experimentalairlines
Flying Wing Calculator
http://fwcg.3dzone.dk/
Free Flight Sim for PC.
http://www.rcdeskpilot.com
Music:
www.freeplaymusic.com
My Day Job:
www.stoneblueproductions.com
info@stoneblueproductions.com
Photo-Video-Marketing-Design
http://www.youtube.com/watch?v=W4EZ8T1qPd4
This footgage is from the same camera but it is much better quality, I want to buy one, but I want to be sure I get that good picture quality like in this video. Are there settings or so I have to change?
Thanks
Casey
I am personally only using it now for hd recording and not both so no i am not sure but would say play it safe and as cool as this is just get two cameras :)
Casey
