Is 900mhz any good?
What kind of range are you getting?
Do I need new antennas?
What are those lines in my picture?
What about the camera?
All I can say is,Yup.I am liking it. The wiring harness it comes with is nice n easy to get it going quick.
Bout a kilometer so far,but you probably want to have nice filters if you are on 2.4 for your control.Got mine from readymaderc.com
If you want to get further away and have better reception,yes.
The 200mw vtx does not filter the power like on a lot of your 5.8 vtxs.So you might want to get one of these.. http://www.hobbyking.com/hobbyking/store/__26246__L_C_Power_Filter_for_FPV_A_V_Systems.html
The camera is really pretty good.There is no easy way to mess with the white balance and as you can see it gets blown out in the sun sometimes.I did also change the lens to one a bit wider.It has nice color for the money.
I took it up and tossed it around.Dives,rolls,inverted...Trying to see how the signal behaved.
I then take it out to 1 km before turning back.No loss of picture.
To be honest,I never flew with the stock antennas,just used em for ground tests,as they are kinda heavy(26g or so).
During ground tests we found them to be quite good.Lots better than the stock performance we got from out 5.8 gear.
12 channels but make sure you are on 910.The whole shebang runs on 12 volts.
Vertical antenna positioning for distance and horizontal positioning for altitude.
Notice the yellow filter.This,and careful antenna placement and you can get out there a ways on 2.4ghz.(the heat sink on the Vtx is probably unnecessary but I am aiming to put this in the wet, so I sealed it.)
Specs from H.K.Here are the specs from H.K.
Camera spec.
CCD sensor type:1/3 color SONY CCD
Pixel;
NTSC: 510(H)*492(V) (included)
PAL: 500(H)*582(V)
Scanning system: Interlaced scanning
Synchronization: System:Inter
Horizontal resolution: 420TV line
Minimum Illumination 0.01LUX/F1.2
DSP+CCD: CXD3142R+405AK
S/N Ratio: 48dB
Gamma Modification: 0.45
White balance: Auto
Auto backlight compensation: Auto
Lens: 3.6MM
Audio: No
Input voltage: 9~12.6V
Electric current 80MA
Electronic Shutter: 1/50 (60) ~ 1/100,000s
Video output: 1.0VP-P composite video
Operation Temp.: -20~50
Flight time: Approx 60min/100mah 3S FPV Tx Spec.
Channel: 4-Ch, AV synchronizationPower: 200mW
Input voltage: 12V
Weight: 18gSize: 31x88x8mm
Frequency: 0.9G 0.910G,0.980G,1.010G,1.040G
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Weight: 18g
Included.
1 x SONY CCD 1/3inch Camera
1 x 900Mhz 4 channel Video Transmitter (200mW)1 x 900Mhz 12 channel Video Receiver
Camera spec.CCD sensor type: 1/3 color SONY CCD
Pixel: 500(H)*582(V) (PAL)
Synchronization System: Internal synchronization
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Size: 38 x 38mm
Input voltage: 12V
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Size: 38 x 38mm
Input voltage: 12V
Weight: 18g
Included.
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Size: 38 x 38mm
Input voltage: 12V
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Size: 38 x 38mm
Input voltage: 12V
Weight: 18g
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Size: 38 x 38mm
Input voltage: 12V
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Size: 38 x 38mm
Input voltage: 12V
Weight: 18g
I will keep you posted as to how well it works in the clouds.
Zat.
Camera spec.CCD sensor type:1/3 color SONY CCD
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Weight: 18g
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Weight: 18g
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Pixel;
PAL: 500(H)*582(V)
S/N Ratio: 48dB
White balance: Auto
Lens: 3.6MM
Audio: No
Input voltage: 12V
Weight: 18g
Just waiting on bits from China to make some up. Thanks for the tip Nonamerc.
This cheepy is for poking at the clouds.I have a S.C.2000 $50 cam but I wanted to see what happens with this one first.
Yeah the lines are a lil bothersome so I ordered one this. http://www.hobbyking.com/hobbyking/store/__26246__L_C_Power_Filter_for_FPV_A_V_Systems.htm
How do I make sure I'm on 910? Great footage, Thanks
- Michael
