Calke Abbey - Spring Preview
by ycopter | June 7, 2012 | (14) Posted in Projects
The National Trust has kindly given me permission to film within the extensive 600 acre grounds at Calke Abbey.  It really is a dream to fly through the ancient woodlands, formal gardens and around the historic house.
In return I am producing a promotional film for Calke.  This extract is taken from two adjacent flights and is 100% actual flight speed.  I have resisted the temptation to edit this too much, most of the footage is uncut which will hopefully give a good impression of the experience of flying through such a beautiful landscape.
Enjoy…
SuperCub92 on June 8, 2012
u really do have an eye for wot looks good.. this looks brilliant and really doesnt need editing :)
keep the videos coming (Y)
ycopter on June 8, 2012
Thanks, more videos coming when I can find time to edit the raw material!
ukbozzy on June 11, 2012
Hi ive pm'ed you.
ycopter on June 12, 2012
Please PM with your email address, I can't send a PM to you, it fails every time, no idea why!
House Of Noob on June 7, 2012
Lovely flight
Thanks
sprout_less on June 11, 2012
Did you do any color adjustment? This looks amazing!
I use PowerDirector 10 to edit and on this video used a setting called "Video Enhancement". It sharpens the image and adds a little more saturation, but to be honest I usually don't enhance the video at all, the raw footage from the GoPro HD2 look great without any enhancement.
Correction, I didn't use any enhancement on this video, I used the "Video Enhancement" on the previous video "Tricopter Testing - HK KK V1 board".
stephen on June 15, 2012
That was brilliant I want one of them
Huwy11 on June 8, 2012
Nice work =D
Were you using a GoPro for the FPV or did you use two cameras?
ycopter on June 9, 2012
Thanks Huwy11.
I have used the GoPro live feed in the past and it works pretty well, but now I use a separate FPV camera and this is why:
1. The GoPro uses average exposure, so either they sky is clearly visible or the ground, but never both. I now use a camera with wide dynamic range (WDR) which exposes the sky and ground separately.
2. If using the GoPro case to protect the camera, you have to drill a hole in it for the video cable to pass through which makes the case non-waterproof!
3. The live output reduces the GoPro battery life quite a bit.
4. When the GoPro battery is exhausted the camera turns off and the FPV feed goes with it!
5. You don't have to have the GoPro onboard to fly FPV.
