How To Reverse a Servo Internally
by Pilot Scott | May 8, 2012 | (15) Posted in Tips
To use a servo reverser or not. While the convenience of a servo reverser is quite appealing but there are some instances where space, weight or logistics don't allow from the easy of a reversing module. The attached video will step you through reversing one internally. I have shown this on a 9G servo but the principle applies to all sizes. Don't let the intimidation of opening up electronics detour you, it's quite a simple process. The basis is reversing the positive and signal line as well as the positive and neutral on the servo motor. Good Luck and hope this helps.
Scott
RCDZK2011 on May 9, 2012
Great Vid! Thanks!
Masen on May 11, 2012
Very nice video
noam3d on May 9, 2012
Graet video!!! Very helpfull!
Thenk you!
Non Action Man on May 11, 2012
I've used this a few times now, thanks to you!
Dodge on May 11, 2012
Hey guys, sorry to sound a noob, but what's the advantage of reversing it this way compared to reversing it via the Tx?
cyasa on May 12, 2012
thanks
Pilot Scott on May 11, 2012
Hey Dodge, if you have two servos on two channels then reversing them with the radio is the way to go but if you have two servos on the same channel and need to reverse only one, then this or a servo reverser is the only choice. The reason, if you reverse it in the radio it will reverse both.
Josh Bixler on May 10, 2012
Love it Scott! That cleans up builds and programming issues!
JB
Stressed0one on May 11, 2012
Solves a lot of programming head aches indeed :)
Also helps those whom want to add flaps to there model.
For example for the Multiplex Fun Cub Flaps ;-)
jetpackninja on May 9, 2012
Awesome tip!
StumpyNubbs on March 27, 2019
