So you want your to do long range/medium range flights on your Bixler?
It's a big investment so first of all do you want to spend the money for a long range system?
What do you need for long range FPV?
- UHF System
- FPV System
- Stable Plane
- Money and soldering skills
UHF System:
There are a few UHF (Ultra High Frequency) systems on the market.
- Dragonlink
+ Proven quality
+ Made in the USA
+ Free receivers if you/friends buy from dragonlink
+- Compatible with dragonOSD (Really hard to setup, manual is HUGE)
- Filtering of the EZuhf is better
- Bad costumer service
- People have allot of issues with dragonlink V2
Price:
269$ No diveristy 12 CH
- EZuhf
++ Spectrum analyser
++ Extreme hopping this mode uses allot bigger portion of the band (430-450MHz)
+ Programable radio update the software yourself
+ Selectable frequencies: 431-433 MHz 433-435 MHz 435-437 MHz 436-438 MHz
+ Legall versions for UK and Germany
+ Proven quality (Used by trappy)
+ Compatible with EZosd for RSSI (easy to setup)
+ Better filtering for 1.2 GHz and 900 MHz
- Costs allot more
Price:
319.99$ 8 Channel no diversity
339.99$ 8 Channel diversity
- Chainlink Dare
+ Cheap only 150$
+ Updatable software
+ Standard diversity
+ Compatible with cyclops osd for RSSI measurement
- Bad filtering (people cant fly chainlink and ezuhf together, chainlink will get failsafe because of bad filtering, also allot less range)
- Not compatible with 1.2 GHz and 900 MHz (Failsafe after 200M)
(There are some people who have no problems at all but the risk for me is just to big)
Price:
150.00$ 11 channels,9 channels for control signal ,1 channel for PPM
My conclusion:
If you have the money go for EZuhf, if you want a cheaper uhf system go for dragonlink. I don't advice you to buy Chainlink Dare.
I hope that this was educational.
This took me 3.5 hours to write be sure to rate this and leave some constructive criticism.
Note:
I am dutch not english so please ignore my crappy english.
Nonamerc
My youtube channel (will open in a new window)
Updated: 10th June 2013
By the way, I fully agree with your perception / evaluation.
Congrats
I have a SkyWalker FPV setup, I purchased a Chain Link Dare system and fitted it to a JRPCMX10 radio.
First 2 flights was very successful. On the 3rd flight 3 minuts into the flight I lost control of the elevator. It done a few loops and came to rest in a tree un damaged lucky enough.
I then done some testing on the ground with everything turned on and every few minutes the elevator goes to full up position for around 10 seconds and then I have control again. The instalation of the CLD and my radio I made sure was perfect.
Im now doing research for a quality UHF system and Looks to me like EZuhf has great reviews.
Thanx for your valuable info..
Ashjay75
The images are not showing up - if you post the links to the images in a comment, I'll fix that for you.
First pic: http://www.terranova.net/~winger/RCVideoStore/DragonLink/Installation/DragonLinkOnTransmitter3.JPG
Second pic:
http://www.bracky.net/images/ezuhf.JPG
Third pic:
http://static.rcgroups.net/forums/attachments/2/6/3/4/4/3/a4408276-39-ChainLinkDare%201.jpg?d=1320934216
Thanks again
I read on dragonlik webpage that 5.8Ghz is not for long range flight, actually mine gets blurry when i´m 600 meters away.
They said that the best is 1.2Ghz, What do you think about? if that is right what would you recommend (a particular brand) to get and how mane mW do i should consider.
I do not want to attemp to get a new world record but at least 5 kms will be great.
Thanks a lot for your help.
Hans, from Lima, Peru
Just send me an email and I will send you some links of the gear that's good to use and which UHF system you should use. Also read my article fpv frequencies for dummies it has some good information to.
