A variation of Ed's, Experimental Airlines, Armin wing which uses Dollar Tree foam board to construct an airfoil style wing, this one being tapered. In this video I make a 10x5 taper, but you can also easily do other sizes. I recently made two 6x4 from one 20x30 sheet.
Great looking wing and video!
The cutter I use is a Logan 6000 Freestyle V-groover.
http://amzn.com/B0039ZWYIY
I did a video a while back with more detail. You can check it out here if you like: http://www.youtube.com/watch?v=I4lZ5EnNMbg
I have been using Carbon Fiber Arrow shafts built inside and between two bottom formers and then cover with the top former to make a bit of a curve. As they would be running along the middle equal distant from the leading edge they would play well together.
What type of center wing stiffing do you use when you put two of you swept wings together???
Thanks for a great demo article, Bryan
