Hey guys, before you watch the video, you may notice that the intro is diferent than the other one, thats because it's an old video of the season 2 and we are now about the season 4, but I thought it was interesting for you to know how to start with helicopters. The substitles are comming in the new videos that we are planning. So we reviewed 4 helicopters:
SoloPro II of NineEagles:
- Ultra-micro size and weight perfect for indoor flying.
- Includes everything needed to fly—there's nothing extra to buy.
- 100% factory-assembled, test-flown and ready-to-fly right from the box.
- 4-channel transmitter equipped with 2.4GHz technology, digital trims and dual rates.
- Flight time more than 8 minutes.
- Recharge time 30 minutes.
- THREE UNIQUE INVENTION PATENT in The World
A. Charge directly on the transmitter
B. Easy installation of battery
C. Allow Mode1 to Mode2 only by antenna
- Model No: NE R/C 260A
- Overall Length: 207mm
- Rotor Diameter: 190mm
- Weight: 27g
- Power System: Motor x 2pcs
- Battery: 3.7V 120mAh Li-po Battery
| KDS 450SV 3D Helicopter READY-TO-FLY: (100% Complete Set) (100% ASSEMBLED!) (100% Ready-To-Fly!) The new KDS450-SV comes with full CNC 120° CCPM head, carbon frame sets, 325mm fibreglass blades and a CNC belt driven tail gearbox. This model is smooth, efficient and lightweight, weighing in at only 750g (approx) with the battery fitted. It is ideal for novice through to extreme 3D... [READ MORE] Package includes: KDS450SV Assembled kit with Aluminum parts Carbon Fiber frame (Installed) 325mm Carbon Fiber blades (Installed) KDS 3500KV motor (Installed) KDS 40A ESC (Installed) KDS 9g Servos x 3 pcs (Installed) KDS N590 Digital Tail Servo x 1 pc (Installed) KDS800 AVCS Gyro x 1 pc (Installed) KDS 2200mAH 3S 11.1V (20C) Lipo x 1pcs KDS balancer charger KDS-3S KDS 220V DC Wall Power Supply for charger KDS K-7X II, 2.4Ghz Radio with 8Ch receiver (Installed) FREE Full sized Aluminum Case x 1 pc 100% assembled KDS K-7X II, 2.4Ghz Radio System: Features/Caracteristicas: LED display, Show model type and battery voltage on normal status. 5 models parameters store supported Support HELI(helicopter) mode and AERO mode. Heli mode: HP1 : Normal helicopter with 1 servo HP2: Swash helicopter with 2 servos HP3: CCPM 120 swash helicopter with 3 servos AERO mode: AP: Normal aero plane VP : V-tail plane DP: Delta wing plane • NEW! Liquid Crystal Display (LCD) • 7 channels standard servo signal output • Support 5 points throttle(THR) curve on NORMAL mode and IDLE mode. • Support 5 points pitch(PIT) curve on NORMAL mode, IDLE mode and HOLD mode. • Set reverse (REV), sub trim (SUB) and travel by digital adjustments • Dual rate (DR) control supported • Throttlehold supported • Gyro sensitivity adjust supported • Return to battery voltage display after no operation till 30 seconds. • Beep when battery voltage low than 8.6V (Once per second) • Throttle-Safe on startup • Simulator Port Items required to complete: -8 pcs "AA" battery for your Controller Specifications: Length: 700mm Width: 140mm Height : 200mm Kit weight: 440g Take off weight: 750g Main rotor diameter: 720mm Tail rotor diameter: 150mm Pinion gear: 13T Main drive gear: 150T Autorotation tail drive gear: 106T Tail drive gear: 25T |
So I hope you enjoy it. As always:
Remember, we are an HONORARY partner of FliteTest and Stonekap Productions Ltd. Remember to check out our website:
http://www.flitetestargentina.webstarts.com and check us in facebook by searching FliteTest Argentina or go to the officcial page:
http://www.facebook.com/flitetestargentina
Thanks for reading...
No Comments Yet
Be the first to leave one!
