I always had problems with the transportation of my quadcopter and this is how i soled it.
This is my build step by step...
I had som plans for a foldable quadcopter based of David Windeståls tricopter and this was the outcome.
I made the quadcopter in 3 mm lauan plywood, its cheap and if something goes wrong you can always do a new one.
Consider it marked.. i taped it so it would be easier to saw.
I used a standard jigsaw to make the parts. The point by doing this is as i did was that i wanted to use as much materials that you can buy in a ordinary hardware store and use ordinary tools.
Testing the frame functions, I changed the positions of the arms after i first mounted it. The angle of the front booms where to tight when i folded it together. The booms are about 10" or 25cm (see the drawings in the end of the presentation)
I used a Hobbywing Quattro ESC for a tight fit and a slim look. Bare in mind that if you use a flight controller with digital compass its better with standard ESCs because it can create some nasty interference on the flight controller if its to close.
This was before i changed the front booms, it is a much better fit further down in this presentation.
I used a bit of vulcanising tape to tape the cables together so they shouldn't get caught in between the booms and the frame when you fold it.
Cables from the ESC and power cable to the BEC.
Some ugly green ties and we are one step closer to the end.
Some big as 1000kv motors, a little bit oversized but you take what you've got.
A special velcro for kitchen panels, it has excellent capabilities of reducing vibration so its very good to use on your flight controller.
A stripped receiver.
An ordinary straw makes a excellent antenna holder.
Just drill a hole and "woala" you have a nice bendable antenna holder.
So when you want to fold it and put it in the bag the antenna stays in one piece.
Antenna and lipoalarm.
Almost ready to test out on the backyard. I use a "Crius AIOP V2" flightcontroller, its the same as Hobbykings "Multiwii AIOP V2.0" and it works excellent.
I use a Hitec Optic Sport 6ch for this quad, i usually fly in Acro so it will not require so much channels on this quad.
Ready to test. Check out the video on youtube of its stability.
Here is a clip that shows the folding
Lets fold it... the back booms folds pretty tight.
and next the front booms and the antenna.
It fits in a small bag like a backpack so its really easy to bring
I use rubber from an old cd-rom to make the dampers for the camera, it has great capabilities to absorb vibrations.
I fitted the camera mount with the same velcro as i used on the plate before.
Ready for new adventures.
I hope you liked this little preview of my new foldable quad.
Have a glorious day.
Black Forest Copters - Växjö Sweden
Here are the drawings for the quadcopter (all plans are A3-format)
This is the drawings for the booms (I used 12mm aspen tree)
Boom drawings
This is the bottom plate (i used 3 mm lauan plywood)
Bottom plate drawings
This is the top plate (i used 3 mm lauan plywood)
Top plate drawings
Hope you like it as much as i do.
//Sirtoby
Can you detail your GoPro mount a little. It looks interesting, and obviously does a decent job.
Thanks
Model: N2830/11
Kv(Rpm/V): 1000
Weight: 62g
Resistance (MΩ): 104
Idle current: 0.6A
Wire winds: 11
Power: 270W
ESC requirement: 20A (not included)
Power supply: 2-4S Lipo
Suggested prop: 9x4.5, 10x6, 10x5
I love your David Windestål's approach to the frame shape. The booms are pretty long too, has that helped your design?
The length of the booms have been changed many times to get the right response, to long and it get a little bit slow and to short get the quad to be a little bit nervous and unstable.
will try that design when I crash my t-copter! :D
Thanks again
Kenny
i used
Hobbywing Quattro ESC 4x20A
N2830/11 1000kv motor with 10" props
An ordinary BEC to power the card
A Crius AIO Pro V2 Controller board
Just finished my build couple of days ago, as per the original template, build detail:
-Openpilot CC3D
- Turnigy Aerodrive SK3 2822-1275
- HobbyKing 12A BlueSeries Brushless Speed Controller (SimonK)
- Turnigy 2200mAh 3S 40C, I have also tried 2 cell (950 mAh) and it was fine
- 8*5 props
All up 780 grams only (without gopro)
All I can say what a sweet little thing, mounted my Gopro, no vibration what so ever, exactly like my QAV400, the most practical frame from a whole lot that I have build the past three years
Well done mate, excellent work
Sal
I really appreciate your feedback
I want to stat by thanking you for your design so far I have build two frames on for a friend with very similar specs to yours except I used kk2 and rctimers 2830/13 850kv motors and it works great.
I'm on my second setup now and I'm having some issues I thing the motors are just to much for this little frame what do you think
Suppo 2836/8 1100kv
Also do you have megapirate or multiwii on your board ? I'm setting up megapirate on hk multiwii pro with gps on it -
You can almost make anything fly, big or small motors, big or small frames it doesn´t matter much. The thing to bare in mind if you have to much power in your motors you may have to have smaller props to decrease the thrust or it can be almost impossible to tune.
Another thing to bare in mind is that some esc doesn't work with multiwii or crius flight controllers. I used a Crius AIOP V2.0 on one of my tricopters with some cheap escs from ebay and i couldn't get it to fly but when i changed it to a KK2.0 it flew like hell.
Try to have as much weight as possible as low as possible it helps to make it more stabile.
I use Megapirateng R2.8 and i tune it in mission planner.
Have a nice one.
They are up and running again... enjoy
