To the FliteTest Community;
This episode features the MESArcFF Team reviewing the new Apprentice 15 Trainer plane. This is by the far the best plane we have ever reviewed for the beginner and Advanced pilots. We would like to thank Gary Kolm from HobbyTown USA and the team at eFlite for sponsoring this episode.
Full Specs:
Assembly TimeLess than 1 Hour
CG (center of gravity)3-1/8 in (79.0mm) back from the leading edge of wing
Charger2 3S LiPo balancing charger, 0.5 3.0A (included)
Control Throw (Ailerons)Low: 0.71 in (18mm); High: 0.91 in (23mm)
Control Throw (Elevator)Low: 0.71 in (18mm); High: 0.91 in (23mm)
Control Throw (Rudder)Low: 1.10 in (28mm); High: 1.35 in (35mm)
Experience LevelBeginner
FlapsNo
Flying Weight49.0 oz (1390 g)
Is Assembly RequiredYes
Minimum Age Recommendation14 years
Motor Size15-size brushless outrunner
Overall Length42.5 in (1080mm)
Prop Size11 x 8
RadioSpektrum DX5e transmitter (included)
Recommended Battery11.1V 3S 3200mAh LiPo (included)
Recommended EnvironmentOutdoor
RetractsNo
Speed Control30-amp brushless (installed)
Wing Area515 sq. in. (33.2 sq. dm.)
Wingspan59.0 in (1500mm)
Get the plane: http://www.hobbytown.com/Shop/APPRENTICE-S-15E-RTF/
MESArcFF
The team unboxing the product!
Construction was very easy and took the kids about 30 minutes to put it together.
Plane is complete, the team talks about the build!
The safe technology is top notch, this is a true and "SAFE" trainer.
Trying to crash it, but it won't let us!
Flies like it is on rails!
Kids learning the stick movements
Landing was made easy!
Stearable nose gear makes for a nice touch!
All smiles!
Thanks,
Thanks Michael
So we just went out and flew it crooked, it wanted to pull that direction on the ground, but not enough to ruin our takeoff. The plane was amazing, the best plane yet in terms of trainers. Now after that flight we did straighten it back out, and now it taxis perfect on the ground. If the weather is bad and you have time, I would just go back and fix it, I know its a pain, but it is worth it. Hope that helps.
Marshall
Thanks for the cool video
Driveandairsmash
