The Avro Canada CF-105 Arrow was a delta winged interceptor designed and built by Avro Canada as the culmination of a design study that began in 1953. The Arrow is considered to have been an advanced technical and aerodynamic achievement for the Canadian aviation industry. The CF-105 (Mark 2) held the promise of near-Mach 2 speeds at altitudes of 50,000 feet (15,000 m) and was intended to serve as the Royal Canadian Air Force's primary interceptor in the 1960s and beyond.
Not long after the 1958 start of its flight test program, the development of the Arrow (including its Orenda Iroquois jet engines) was abruptly halted before the project review had taken place, sparking a long and bitter political debate The controversy engendered by the cancellation and subsequent destruction of the aircraft in production remains a topic for debate among historians, political observers and industry pundits. "This action effectively put Avro out of business and its highly skilled engineering and production personnel scattered . Many went to either NASA to work on the Space Shuttle or to England to work on the Concorde
Here is my attempt at designing and building the Avro Arrow. I'm still learning how to make plans so dont be too critical on the pdf file I made . The plans are pretty close but some tweaking may be necessary I made the wing and fusalage seperate and use bbq scewers to hold them together. This way I can get at the electronics easily and do not have trap doors .The decals are just printed on plane paper and glued on with a glue stick
First flight was short as another 50 foot tree jumped up and grabbed it. It did fly but using an old radio with no programming was a challange for a newbie . A few days later and after a wind storm I got it back..
Built version 4 and she flies real nice. I increased the wing span and gave it a larger stab. I'm not using rudder control just elevon .
Parts all laid out ready for assembly
I made a slight change after flying this one I have removed the bottom piece shown attached to the wing and extended the fuse to incorporate it . It is all now one peice and the battery is much eaiser to get at.
Servo installation
Ready for some colour
Lets go flying
Using
9 grams servos
30 amp esc
9x6 prop
2200mah battery ( Battery is placed just behind the nose as far forward on the fusulage as possible )
2215-15 emax size motor
Not too good of a video but shows how well she flies when you can see it
Nice to see a fellow Canuck on flite test nice build super simple construction.
Very similar to rcprarieflyyrs arrow which is an excellent build with awsome instructions.
I prefer the engine mounted at the rear wonder how they would go as an edf
Great to see another arrow lets keep the canadian planes coming
https://www.flitetest.com/articles/avro-arrow-pusher-dollar-tree-foam-board
