FTScratchBuild-Advanced
The FT Baby Blender (Version 2) is an updated version of our original foam board scratch build! We took input from you (our viewers) and redesigned this scratch build/ speed build kit with added strength, better flight characteristics and a much easier build experience!
Baby Blender v2 Step-By-Step Build Instructions [HERE]
We've kept the dimensions the same, but we've improved the design and ease of build for the FT Baby Blender Swappable (version 2).
Among the improvements are elevator notches into the fuse to align both fuse and tail at one time.
The bottom of rudder is stronger and is secured by fuse sides.
The elevator incidence and thrust angle has been changed from the previous design, removing any pitch changes when the throttle is changed.
Higher lift airfoil and tabbed wing spars for easy build and improved flight characteristics.
Landing gear mount is stronger and easier to install.
We want to thank all of you who have built the Baby Blender and have given us feedback to help improve the scratch build design!
We've made this scratch build also available as a Speed Build Kit available in our web store!
Be sure to check out our Decal Kits as well! Thanks again for all the feedback and support!
Thanks again for all of the input on the previous Baby Blender scratch build! We'd love to see and hear your results with this new design. Be sure to submit your photos, videos and input on your builds!
MORE PHOTOS available! (CLICK HERE)
Join the discussion and submit your own builds in our Forum Post!
FREE Build Plans:
FT-BabyBlender-Swappable-v2-PLANS [FULL SIZE]
FT-BabyBlender-Swappable-v2-PLANS [TILED]
FT-BabyBlender-Swappable-v2-PLANS [ALL IN ONE]
Click HERE to see the POWER POD BUILD VIDEO
Equipment used in this build:
FT Control Horns
NTM Prop Drive Series 28-26A 1200kv / 250w
Hextronic 9 Gram Servo
TURNIGY Plush 25amp Speed Controller
Turnigy 1300mAh 3S 25C Lipo Pack
Linkage Stopper "Speed Clevis"
.81mm piano wire (push rods)
Futaba T8FG Super 14ch Transmitter w/R6208SB 2.4GHz Receiver
Futaba R6106HFC 2.4GHz FASST Mid Range 6Ch Rx
Additional/Alternate components:
Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
APC-style Electric Propeller - 8x4E
Suppo SP-90 9g Micro Servo
Good job you gotta $250.00 plane there..!!
This is simply another first class video and design, well done.
I enjoy every episode and wait impatiently for the next.
Thanks guys for what your doing!
Whats better than Baby Blender? How about BB v.2
EXCELLENCE!!!!!
Now I would like to see how it behaves with symmetrical wing profiles (or at least close to symmetrical), because I cannot leave that thought when I see pilots pilot the baby blender.
I still need to make up wich FT plane to build as my first. Got some old foam sheets from the -90s some laminated with a local butchers & chark producer advertisement.
That sure will be heavier but then waterproof on one side :)
Should get some sponsor money if i build with that.
My looks like the old one you had .. and this one looks way better.
thanks again, fellow scratch builder
thanks
What battery are you using? Plans say 3S but parts list above call out a 4. I have both but want to make sure I'm running the right power setup.
You could run it on 4cell but probably to minimal advantage. You would need to get a lower KV motor to have the same rpm but you will get more punch when needed on the 4s system. I think the parts list has an error.
The motor I am running (Turnigy 2826-10 1400kv) only takes up to 3s.
After printing your plans, you begin to piece together how they will assemble. This is a bit of a puzzle project but it is entertaining in its own way.
As you match the pieces, use scotch tape to hold the pieces together, it does not matter that you paste over the lines, you will simple cut through the tape.
When you have finished your plans, take them somewhere that you can turn them over, turn them over and use a photo mounting type of spray glue. Mine was by Elmer's I think. It is semi tacky so you can readjust if need be.
After spraying the glue to the plans you simply attach the plans to your foam board.
Then the razor cutting begins! The plans don't move and since you lightly tacked them with the glue you can remove them when you are finished.
Wood workers use a similar technique with patterns and rubber cement.
No need for pins, nails, weights or swearing at all.
Perhaps I should do a video if you guys are interested.
Mark W.
Four FT planes and counting!
I would also look at extending the tail by 3-5 cm as it is very twitchy as-is and adding more lift will make it more so. A longer fuse may help mitigate this.
I would be interested in seeing a tri version of this.
I am glad that I came to your site and turned out with a new hobby of building rc planes from scratch. I am a new bee in RC planes and i build a baby blender 2 by your instructions. My plane looks great and Storng enough, wish i could share my pics or video here.
Your instructions were superb and the plane also turned out good. As I am a new bee it was my first flight with my baby blender 2. It was a nice experience and i was afraid to take it in air at first as it was looking so cool that i though I should not brake it.
Any ways i took my first flight and after few wrong start up i managed to put my plane in air.. say about 3 feet from ground, but suddenly my plane tumbled and my horizontal wings went vertical and plane crashed.
After few more tries and crashes the upper and lower wing started wobbling as the linkage between upper and lower wing had some folds. Also my power pod came out of the barbeque sticks due to crashes and the foam paper teared off.
Can you suggest using a candy stick for wing support and to have power pod in place is a good idea.
But i admit it was very exciting, and nice experience to build this plane right from scratch.
I took lot of patience to do every step and it was fun to see the plane getting into shape step by step.
Thanks Josh B for wonderful video, awaiting your response on the issue i faced.
Regards,
Lalitya
I'm going to try the BB. to increase by 50%.
So that the baby becomes a teen.
Then it does not say BB. but TB.
I hope that the good flight characteristics are maintained,
or be even better.
regards Franz
also, in the power pod video, he inserts the skewers through the firewall into a square of foam board. on mine the skewers go right over the top of my square piece of foam. I would have to use a double thickness of foam board for it to work.
it make me think the fire wall is too tall, but again i compared it to the plans over and over and it matches.
I am using the plans i downloaded here.
