This is my fpv station bag
Inside
This i made for the sunny days!!!
My monitor 7" TFT LCD Headrest Color Car Rearview Monitor VCR DVD | eBay
So,i cut with my demmel the back of the monitor base
My receiver RC805 - 5.8G 8 Channel AV Receiver
I use another antenna FPV 12dBi 5.8GHz Antenna but you will need an adaptor SMA Female to RP SMA Male Jack RF Adapter Connector | eBay
Power supply for the receiver
AV connec from receiver
The blue is useless ,,,
The bottom base of monitor has a sticker ...use it to to put the base monitor
I wanted to have my receiver on monitor...your choice
connect power supply to the receiver
use something to keep the cable at the hole because is moved all the time and you gone lose your image
connect AV
This come from receiver
Do not push very much!!!!!!!!!!!
ok let's connect enerything
Turnigy 2200mAh 3S 20C Lipo Pack
camera 1/3-inch SONY CCD Video Camera (PAL) and a better lense 2.1mm F:2.0 Turnigy Micro FPV Camera Lense also FPV Fiberglass Pan-Tilt Camera Mount L-Size
i used that video to connect the camera with trasmiter HobbyKing 5.8Ghz FPV Setup - YouTube
also 5.8G 200mW FPV Transmitter
ZIPPY Compact 850mAh 3S 25C Lipo Pack for trasmiter
