all the wings including damage. the black and strait green strips wing are 35-36" (same wing profile) the little one is 26" the red and yellow wing is 40"
Here is the dove tail motor mount, you can see the spring loaded anttena mount as well.
another look at the dove tail base. I dont like this plane's hatches you can see i have damaged the center section.
here is the motor attached to the base.
the sketch up view of the mount.
this is my favorate hatch configuration. seems strong enough the back part pivots over a spar
MOTION SICKNESS WARNING!!! these videos were not intended to be quality, just to test flight capibililties
the green 36" you can see its bumpy and yaw stability is not so great, sorry about the jello, I did not put in any vibration dampinging for these flights.
red 40"
The versa wing and fury flyer are both great wings but have some undesirable characteristics i am attempting to change, first and foremost is low speed maneuvering. I am flying at a field that is 117yds by 75 yrds. with pine trees on 2 sides. There is a horrible wind shear as i pass 80ft in AGL. I need a plane capable of stable, gentle, efficient flight, but also capable of punching thru the 80ft boundary then some low speed crazy tight maneuvers (for landing on windy days). (plus I enjoy a crazy responsive fast wing) The composite picture shows all my current attempts, including one failure. The folded wing was my favorite however it didn’t have enough strength to survive repeated full speed dive pull outs. On the third battery I during a hard pull out she folded sending a 2200 mah 3 cell strait at my head. My favorite surviving wing so far is the larger of green strips it is 36” semi symmetric wing 33degrees of sweep root cord 11.5 tip cord 5.5 and versa style elevrons I fly both with and without a Gyro though it hardly needs it.
My last challenge is eliminating Dutch roll at all speeds, and decoupling yaw and roll . (suggestions welcome). I am hoping 3 degrees of negative dihedral will fix this I use sketch up to design my planes.
Since I was testing multiple wings and wanted identical motor/prop performance, I designed a dove tail motor mount (3d printed) that not only allows me to slide the motor forward and aft but also to quickly switch the motor from one air frame to another. If anyone is interested I can send you the STL’s or upload them.
Motor is Exceed rocket 2210 1650kv
30amp proto esc
Prop 8X4 apc
Servos: (2) solar A107
Receiver: frsky D8R-XP
Gyro: DYNAM 3GS
Cam: Turnigy 808 key chain cam
Fight time: Min throttle 25-30mins WOT: 7-9mins
Wing loadings have been from 9-11.5 ounces per square foot.
I intend to change the Gyro out for a Multiwii Flip 1.5, NEO-6m GPS and 3dr telemetry. My Final goal is autonomous flight with FPV.
Once this design is finalized I will publish designs.
I don’t have a HD cam yet so the included footage Is from 808 cam. The first video is with a the 36” green striped wing(gyro set to high) the second is the red and yellowing (no Gyro) It’s a bumpy day, wind is 15MPH on the ground gusting a lot, I was not flying with the intention of making a good video, so be ware if you get motion sick
EDIT added files as requested: All mine were printed in PLA, so no ABS testing has been done on them. I welcome feed back, i have lots of designs and am willing to help people who ask!
Some experiments on the web that are related:
http://www.flitetest.com/articles/split-elevon-air-brake-testing-on-flying-wing
https://www.youtube.com/watch?v=Bx7KWibSWoo
http://plane.ardupilot.com/wiki/differential-spoilers/
