this is the build of the space shuttle
sorry for bad English (I am from Slovakia)
cut the edges
measure horisontal 34cm and vertical 2 cm and draw it
measure vertical 4 cm from the line before and draw horizontal 32cm , than line the edges with the previous line
than measure vertical 21 cm form the hollow and horizontal 15 cm
than measure vertical 4cm from the line that you drew before and horizontal 14 cm and than line the edgeswith the previous line
than cut it out
sand it with a sandpaper 180
tape the edges
take a big cardboard
lay the wing on the cardboard
retrace
match the hollow at the wing with the cardboard
retrace
cut the second wing
match it
cut the rest of the wing/ on the edge of the wing 3cm and on the other side 7cm
tape it
when you have it take a fan and heat the tape
bent the edges
take hot glue and glue two parts of the wing
when you have it take a cardboard and draw a triangel vertical 32 cm and horizontal 14 cm
cut it out
make two parts
tape the edges and glue two parst together
glu them on the wing
now fuselage
take a cardboard
make with knife hollows and bend it
make three stripes and glue them with the fue.
place it on the space shuttle
make vertical stabilizer
cut a line and slide in the vertical stabilizer
make the front of space shuttle
thanks for taking time to watch my build of space shuttle
if you want to build this plane i recommend using foamboard :)
