From this
To this
This build log follows through 10 months of planning, head scratching and construction starts and stops until the final product, complete with the most amazing paint job I've ever seen on an aircraft, takes flight. And, man does this thing fly well!
http://forum.flitetest.com/showthread.php?2368-fpv-flying-wing-build-log
Today's video (5/3/2013) was shot from a HK wingcam attached to my highly modified HZ Super Cub. The Cub is no slouch, but couldn't even begin to keep up with the fpv flying wing - now named by my buddy, Mike Grandi for whom I built it, as The Raven. Grandi is quite an artist and covered this wing in an amazing paint scheme. He blows it off as if it were nothing. That's because this guy is INCREDIBLY talented.
Mike is flying the Raven and I am trying my best to keep the thing in frame as my HZ SC is tossed about by the wind. The wing was rock solid. The Cub, not so much...
I urgently recommend you to downsize the winglets! About half their height and a third of their thickness will do for sufficient directional stability. They will cause much less drag and you might gain some speed.
Needs a few prop strikes and some grass stains. ;)
Are you a Devil worshiper?
I didn't watch the video because of the sculls, just thought I'd let you know
