If planes have mustaches, then they must have faces, right? In this Flite Tip, the Joshes tell us that the cowl is the face of the plane, and going on the idea that you only have one chance to make a good first impression, you better make sure the face of your plane looks it's best. Josh Bixler shows a simple yet very effective way of making sure you line your cowl up perfectly while Josh Scott breaks out some helpful colloquialisms. With some simple materials that you likely have on hand, you'll be able to mount the cowl right the the first time, making your plane pretty enough for that video close up. Keeping it that way will be up to you.
