Ok got a short video today. Its not great as the wind was still very strong (as you will most likely see). As soon as the weather begins to co-operate I will post a better one and maybe one of version 2.0 hopefully adapting some of the suggestions people made (Thanks for those everyone!). Its just a very quick video I threw together before work so its not the greatest. Gopro on head and a keychain camera on the vampire.
I was fooling around with some ideas for my swappable pod and thought I would have a go at a swappable DH Vampire pusher prop. I made it completely from scratch, making things up as I went along, using techniques I learned right here on flight test, but it was a very simple build. Its a very simple conversion from the standard power pod just reverse two wires and turn the prop around. It is only version 1.0 and I have to make a proper fitting for the power pod to fit into yet but it flies really well.
Only three servos elevator and aleron
It actually glides pretty well too
So weather sucks here again with heavy rain and 30 km/h winds. The plus side is that version 2.0 is well underway
New and much stronger tail section using a box style. A bit shorter too hoping to reduce the amount of nose weight needed in my first version.
I am putting a rudder on this version just for giggles as it flies just as good without them.
Here is a look at my pod locking mechanism, just like others in the swapable series.
Fits nice and snug.
Fuselage on this version is slightly longer and narrower. All that is left is the wings.
Ready for electronics!
Great plane otherwise and I'm looking forward to the video.
few thing that you may take into consideration :
1. make true airfoil , not KF step , looks better and perform way better , both symmetric and asymmetric ones.
2. maybe use the "swappable swappable" style they did with the cruiser for FPV / regular nose..
looks nice m8
