DIY Pocket Transmitter
Definitely different looking and feeling, The wood and brass is a nice retro touch.
The pocket TX is much smaller than the regular Horizon 4Ch TX.
The guts of the spektrum radio
The simple board layout makes intergration into other projects super easy.
The modified TX board and the one right out of the unmodified TX
Don't put the screws in this part of the TX though! The spacing is too close and may bridge contacts.
4X AAA batteries equals 6Volts!
The other half simply slips over the back cover
You can use the TX for all sorts of projects!
Flies just fine and dosent feel much different than the other transmitter.
FREE PLANS
IF PUSH COMES TO SHOVE USE DIGITAL SERVOS THEY CAN BE REVERSED WITH THE SERVO PROGRAMMER AND END POINTS SET TO MATCH.
Thanks mucho.
I have one of these, but with a broken antenna :).
They also don't have reversing or anything like that, but you can reverse a servo itself pretty easily by opening it up and swapping the 2 outer wires that go to the pot inside, so you can make a small transmitter system for a specific plane. As for V-tail or Elevons, you can make a small onboard circuit with a tiny 12C508A PIC chip and a couple of disk capacitors that you just fit inside the plane on the channels you want it to mix.
The WLToys V9xx transmitters (the V2x2 ones use a different protocol based off the nRF24L01 chip) use 6 batteries to power them, so you can just use a small 2S LiPo to power it, or as I did, just get 2 old cellphone batteries (same make and model of course) and turn them into a small 2S Li-Ion which gives a lot of power at a very small size.
Would these work together? http://www.banggood.com/DIY-FRSKY-8CH-Receiver-RX-PPM-Output-For-X9DPLUS-XJT-DJT-DFT-DHT-p-987247.html
http://www.banggood.com/Wholesale-WLtoys-V911-V912-V913-V949-RC-Helicopter-Transmitter--p-42822.html
This is awesome. I want to use my old champ or delta ray parts to make a scratch build. Any suggestions on a FT design that would be compatible?
I built it, and my gosh, how cool simple, and yet so great quality you made the design!
