Background
This is my addition to the swappable scratch-built series. It uses the standard power pod,and the tail is similar to the FT Flyer, but with different dimensions. It is a double swappable, because not only is the power pod swappable, but you can swap the main wing - use either the plain wing, or build one with airelons.
This plane could also be called "Scrappy" as it was not a deliberate design. I had built the Nutball and FT Flyer swappables, and was working on a plane similar to Ed's "Axion". Due to trail and error, I ended up with some spare parts and realized I had the makings of another plane. I didn't think the swappable power pod would have sufficient thrust, but with nothing to loose I gave it a try; and was quite happily surprised with the results. Going back and looking at the numbers (see the bottom of this post), I should not have been surprised.
Construction
To start, build the three main components (see related articles for details of each):
- The power pod
- A 30 inch square tube fuselage (2.5 inch inside dimensions)
- A 30 inch armin wing - 5 inch cord, no airelons.
Fusalage
Tail
Wing(s)
Accessories
I need to do some more testing, but this plane may meet my needs for some conservation work I am experimenting with - a stable platform for photography (hence why this design has winglets, and not airelons). I made a small removable 'sled' that attaches under the wing, and it easily flys with a keychain video camera.
The numbers look good for carrying a Android phone which can give both HD video as well as time lapse photography. Even with this small motor, another 4 oz should keep the numbers in a comfortable trainer range; if it doesn't work, I can always swap out another power pod with a bigger motor.
Here is the plane by the numbers:
Full out weight: (with 1000mw 3 cell LiPo battery): 16 oz
Wing area: 1 sq ft
Wing load: 16 oz/sq ft (nicely fits a light trainer definition ~15 oz/sq ft)
Stall speed: 14.8 mph (= 3.7 * sqrt(weight/area)) This is a rough calculation, but good for a start
Turnigy Park 300 Brushless outrunner 1380kv = 77 watt (good for up to a 1 lb trainer: 60-75 watt/lb)
1380kv * 11.5V = 15870 rpm
15870 rpm * 8x4 prop = 63480 inches/minute = ~60 mph max speed (theoretical)
Even if the real max speed is half of this, it gives a nice cushion between stall speed and full throttle.
Update 3/17/2013
I was having trouble with the original wing. Even trimmind down the winglets did not change the flight characteristics. It seemed to 'tip-stall'; turning right and nosing over. I am still not sure what the problem was, but since this is a double swappable, I swapped out the wing. It was easier to try something new than be frustrated trying to fix the problem.
My current wing roughly follows the dihedral idea of the Swappable Trainer. I made two 20 inch Armin airfoils. The bottom side was 5 inches, and the top was cut to 6.5 inches (cut the form board 11.5 inches wide). This left some excess overhang, but rather than cutting it off or turning it into airelons, I left it at a 6.25 inch cord. I trimmed the ends a bit to join at an angle and form a dihedral, and made a small bottom brace similar to the one in the Swappable Trainer that gives a flat mounting surface. Several flights with this wing have all had smooth stability and control.
Keep up the great work!!!!!!!!!!!!!!!!!!! ;)
