Instruction on how to set up a Spektrum DX8 for a two switch six mode switching option.
Uses one channel and two mixers.
Assign the Aux1 channel to the gear switch (in the system menu):
Adjust travel for the Aux1 channel:
Set up first mix:
Set up second mix:
If set up correctly, you should get these values when switching:
| Mode switch | Gear switch | Travel [%] | Pulse width [µs] |
| 1 | 1 | 65 | 1765 |
| 2 | 1 | 45 | 1686 |
| 3 | 1 | 0 | 1508 |
| 1 | 2 | -85 | 1170 |
| 2 | 2 | -65 | 1248 |
| 3 | 2 | -20 | 1426 |
This is an example of a ArduPilot flight mode configuration:
Keith
