Introducing Flite Test SkyFX Pre-printed Speed Build Kits (PSBK). Flite Test SkyFX aircraft are just like select other Flite Test speed build kits, only now with graphics printed right on the foam! The process used to accomplish this utilizes water resistant, UV cured inks giving rich colors and durability. Identical to their plain brown and white cousins, Flite Test SkyFX Speed Build Kits use the same build techniques and have their own special build video with hints and unique tips to maximize the effort of the build. Each aircraft comes with an amazing amount of scale details; for example, panel lines, nomenclature, exhaust streaks, and rivets. Details that are nearly impossible to achieve with just a rattle can, and that would take hours of your flying time if hand drawn, now come included with every SkyFX kit! Each SkyFX SBK gives you all the color and detail you could want with the convenience and ease of a Flite Test speed build kit.
With every FT SkyFX aircraft you will be able to choose from multiple popular color schemes (aka liveries). Each individual color scheme has its own history, look, and feel. And when possible, we research each livery and base them on historic or currently flying aircraft that can educate, inspire, and honor our aviation heritage.
