FPV GROUND STATION WITH 19" SCREEN
by casonjimmy | January 26, 2013 | (8) Posted in Projects
BOUGHT FROM: Hobby Wireless.com
T905 Transmitter 900 MHz 500 mW 900MHz High Sensitvity Receiver HIGH GAIN PATCH ANTENNA 900Mhz 8dBi Nano Microphone w/Volume Control
BOUGHT FROM: Securitycamera2000.com 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera with OSD Menu DNR
BOUGHT FROM: Walmart VIZIO's 19" Class Edge Lit Razor LED™ LCD HDTV
casonjimmy on January 27, 2013
I might do a build video on this soon... Until then.... This is what I did.
I got the tripod from walmart. Then cut a 1 x 4 inch board drill holesmthen attached the board to the tripod with zipties. Then attached two Screw-In Tool Hangers to hold the monitor, http://www.walmart.com/ip/Lehigh-SH13-25-Screw-In-Tool-Hanger/19870521
http://www.walmart.com/ip/Targus-58-Camera-and-Camcorder-Tripod-TGT-BK58T/16524297
http://www.walmart.com/ip/Vizio-19-Class-LED-LCD-720p-60Hz-HDTV-1.2-ultra-slim-E191VA/20461471
Ignore this,, I didnt proof read before posting. See the next reply..... Doh,,,,,
Then cut a 1 x 4 inch board drilled holes for mounting then attached the board to the tripod with zipties.
Reply
Buzz Bomb on January 27, 2013
Thanks for explaining. =)
ShawnG on January 27, 2013
Awesome set up, thanks for sharing, I have one question, when the screen looses signal does it blue screen or get fuzzy? let us know.
Thanks!
Hope it's fuzzy. =P
It goes blue after a certain percentage of loss. It will flicker a little when I get to the edge of my range. There is a setting on the television for blue screen or static in the menu.
Sweet! The tripod mount you are using to hold the TV, where did you get it?
Gopherdave on October 19, 2013
Hello
I like what you did here and I want yo do the same with a similar TV and build it into a pelican case. I assume the screen has a brightness of 250 nits as most do, it looks like yours is bright enough. I was going to add more leds to my screen to get it a little brighter, do you think that's necessary?
casonjimmy on October 19, 2013
This screen is plenty bright. You might notice the shadow on the ground...We are in the shade of a metal cover at the airfield. It is still very bright sunlight and we see perfectly When we fly in the direct light I just add a simple folded cardboard Shade to the top and sides secured with duct tape....
