For more information about Fat Shark RC Vision Systems: www.fatshark.com
Alex (iBcrazy) collected the top LRS systems from R/C pilots that sent their privately owned systems to test.
LRS Systems test units include:
Flytron Open LRS
Rangelink
DragonLink
EzUHF
Sherrer UHF
iBcrazy's helmet was setup to simulate a very bad and extreme R/C airplane setup.
On a his vintage motorcycle, Alex strapped on his helmet and ran a series of tests including stray frequency testing, in-band Interference and more. You can watch the full test and read more in the article here.
Riding the motorcycle towards and away from the ground station, Alex was able to have relatively consistent testing conditions, matching speed and distance with each system test.
With the help of Jeremiah (Bond jr. of StoneBlueAirlines) Alex was able to test video signals on the ground stations. In total, they spent over 100 hrs. on this project!
After all of this testing is the Flytron OpenLRS is Alex's favorite. Cheap and hackable.
For a really reliable unit, Alex chooses the EzUHF system.
Along with the the test results, Alex shares some great tips for setting up your own LRS FPV system. We'd like to thank Alex (iBcrazy) for sharing his test results and LRS FPV tips!
Check out the full test video and read more details in his article linked below!
You can learn more about FPV, antenna's and other Stone Blue Airlines stuff here!
Also be sure to join in the discussion and check out more photos here!
Special thanks to Fat Shark for sponsoring this episode!
My gut feeling is that I would have more confidence in this sort of testing if it was done over real distances, minimizing the use of attenuators. Even on the transmitter side, a poorly designed transmitter can be spewing lots of RF from its circuitry as well as the antenna output, invalidating the effect of an attenuator on the antenna.
Thanks!
Thanks.
The 5.8 here can be just a 10mW unit for the jump.
100mW OpenLRSng (HK)
http://www.undcon.com/2013/06/15/bixler-waypoint-test-in-strong-wind/
