I built it to his specs, then I made a few of my own adjustments. The biggest change I made was a lower KV motor with bigger props. The airframe is made by Multiplex. I have put many hours, and many more miles on this aircraft and it's just about to be removed from commission.
Currently it has a crinkled front-end and some mud stains from it's most recent nose landing. While it still flies fine, I'm eager pull out all the electronics and start fresh with a new airframe that has no holes, excessive glue, or gouges. I highly recommend this platform to anyone who has an interest in serious FPV flying.
I've flown for more than 25 minutes on one 2200 3S. It's very stable and has lots of power! Below are a couple of pictures to show the internal workings. Please comment if you have any questions.
Written by: Chad Kapper
Of course it would be mounted in such depth that wont obstruct the image
http://www.amazon.com/SE-FC9955-Security-Camera-Flashing/dp/B000XBMP5E
Use the dome. $5 to save the GoPro, sounds good to me!
Where did you buy the 9x7.5 props? Hobbyking? Here are the ones I found at hobbyking but they don't look like the ones in the picture:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10393
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16063
-Thanks
Try these:
http://www.hobbyking.com/hobbyking/store/__11332__9x5_Propellers_Standard_and_Counter_Rotating_6pc_.html
http://www.hobbyking.com/hobbyking/store/__11333__10X6_Propellers_Standard_and_Counter_Rotating_6pc_.html
http://www.hobbyking.com/hobbyking/store/__25105__Glow_In_The_Dark_9x5_Propellers_Standard_and_Counter_Rotating_6pc_bag_.html
-Thanks
