FTScratchBuild-Advanced
Here's the full step by step video tutorial showing how to assemble your FT Cruiser Speed Build Swappable kit. This foam board twin engine is also available as a scratch build with the free build plans available below.
The FT Cruiser is a direct result of your input! The Cruiser project started when we received many requests to build a Twin swappable. The FT Cruiser was inspired by the D.H.88 Comet introduced in 1934.
You'll need to build two power pods for your twin engine swappable.
Be sure to watch the supplemental video below to see how to connect your electronics, make your custom connections as well as setup and install your FPV pod and more!
Use the included throw gauge for proper control surface throw. Be careful not to get too excessive on the elevator because pitch control is very sensitive. 30% EXPO on all surfaces works great.
FREE Build Plans:
FT Cruiser - Swappable [ FULL SIZE ]
FT Cruiser - Swappable [ TILED ]
Click HERE to see the POWER POD BUILD VIDEO
Recommended Electronics:
Packs - Power Pack C Twin
4-6 Servos - EMAX ES08A II
2 ESCs - BLHeli Series 30amp Speed Controller
Battery - Lumenier 2250 3s 35C
Check out more photos from this build and share your build photos in our forum post CLICK HERE!
For anyone who's built and flown this yet, how's the torque effect?
I look forward to scaling this to 60% for 3mm depron. Now I have to build a different set of modded power pods (http://forum.flitetest.com/showthread.php?3365-Swappable-fleet-on-the-way) for twin-engines. Thank you Flitetest folks.
Cheers!
Randall
That is my fault! I will get them up asap!
Josh B
short question do you use a special hot glue or will just anyone be okey?
Thank you! Awsome work!
Would it work with 2 50mm Jets ?
http://kiwitricopter.blogspot.co.nz/2013/04/what-about-twin-jet-cruser.html
JB
JB
JB
~psguardian
I would also LOVE for Flitetest to sell a kit for David's Linear Voltage Regulator he uses on the Tri2.6HV. The regulator would complement a 4S setup on the Cruiser for FPV!
Cheers,
Michael J
I recently recieved my ft cruiser kit and have had a lot of fun building it. I noticed that you guys at flite test added canopies. How did you make those?
Thanks
If so could some one send me the link.
Thank you!
NTM 28-26 1350kv http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=35673
NTM Prop Drive 28 Accessory kit http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=24527
Turnigy MG90S Servo's - http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=23594
20 A Turnigy AE ESC - http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=28122
Nano-tech 3s 2200 mah battery - http://hobbyking.com/hobbyking/store/__20432__Turnigy_nano_tech_2200mah_3S_25_50C_Lipo_Pack_US_Warehouse_.html?strSearch=nano-tech%202200%203s%20us
2 Propellers (I wanted them to rotate opposite each other) -
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20333
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20334
Hope that helps
How big is the speed build kit box for the FT Cruiser? I want to order it, but I live in Europe so I need to know the size for the shipping. Maybe you guys can tell me how heavy the package is, that would be great.
Greetings Nicolas
https://www.youtube.com/watch?v=Gf4IULvTP1Y
This would make a great mosquito!!!
I have to try to figure out how to make the wing 2 pieces for transport.
I am guessing I will double the spar, and make a tunnel for a cf tube or box.
This will require altering the saddle and attachment method of the wing, hello rubber bands, my old friend.
I need a cheep power pack
really,I don't have much money
FT Cruiser is very nice.
And your image is looking really good!!!!!!
Does anyone have measurement of plan?
please help!!!
This is Faiz from Pune, India. I am totally new to this RC hobby and Flitetest as well. I Just can't explain in words how much i love your each videos and flying. Big Indian fan of Flitetest. I have already built Raptor f22 with depron beautifully (Config: Emax 1200kv 2822 series motor, 30Amp ESC and 1250mah lipo) but unable to fly it, broken 3-4 times and no clue where i am getting stuck. Now trying to build this cruiser and in India it's really difficult to get this KITs shipped. Could you please help me out with the motor, ESC and other specification (Kv size, weight etc) so i can get it from local hobby store and build this cruiser.
I would much appreciate if you can help me with F22 as well.
Thank you !
Faiz :)
