FTScratchBuild
Our latest foam board airplane, the Edge, is a Red Bull Air Race inspired monster. Here's the low down on how it flies.
The FT Edge - it's power, it's performance, it's sheer foam board taken to an extreme level. Andres Lu, our interning mad designer here at Flite Test. If you're wanting to know more about how this thing goes together, along with what sort of specs to expect, you've come to the right place.
Flight Video
What are the specs?
Quite simply, the Edge is an absolute beast. Based on the full-scale Zivko Edge 540 V3, it has been designed to be a pure all-round aerobatic performer.
In terms of your power setup, we recommend that you use a 425 sized 1000kv brushless outrunner. These can be found on our store in our Power Pack C. This gives you enough beef to pull off some serious moves whilst airborne. You'll also be needing a 10 x 4.5 prop (for a 3s) or a 9 x 4.5 (for a 4s), or else you won't be going anywhere!
You'll also be needing an ESC to go with your motor. If you're using the recommended setup, you're going to need to use at least a 30 amp. Again, you can pick up a complete Power Pack from our online store along with your kit. This way you'll receive all of the same electronics the Edge has been designed around.
In terms of making your control surfaces work, you can choose to run either simple 9 gram or higher performance es3154 metal geared servos. Having this upgrade with lots of extra torque can be helpful when it comes to performing high-G maneuvers and that sort of thing.
The all up weight of the plane, fully loaded with a battery all ready for takeoff, is just 1.5lbs (680g). Combined with Power Pack C, this provides a great power to weight ratio. Unlimited vertical? No problem. Soon enough, you'll be somersaulting and back flipping your way through the air. As you might imagine, this airplane is quite the head turner.
What sort of performance can you expect?
There are three directions you can take your Edge in. The first one is pure 3D. Andres has set the bar extremely high by enabling the Edge to fly in much the same way as the top aerobatic RC planes out there. Axial rolls are a thing of beauty. As mentioned in the release video, the thrust line, wing and tail are all aligned with each other to produce crisp lateral authority.
The second way you can setup your edge is to go full on Red Bull racer with it. You can upgrade the motor and ESC, dial down your throws and increase your expo to create an RC race plane worthy of the Edge name. With a good power system, you'll be hitting some serious speeds in no time.
The third way to build an Edge is to go somewhere in between the first two options. Like all of our designs here at Flite Test, you can customize to your heart's desire. You can squeeze some decent speed out of the airframe whilst having enough aileron, elevator and rudder authority to pull of some snap rolls, wing overs and occasional back flips.
Is this plane for you?
The Edge may look intimidating, but like all our planes it can be made by anyone with some practice and patience. You can follow our upcoming build video step-by-step to assemble one from a kit in just three to four hours.
This is a great intermediate plane. As a four-channel, it's probably best if you have flown one other four-channel airplane before this one to get used to banking and yanking along with carrying out coordinated rudder turns. This way, the extreme throws of the edge won't throw you off too much.
If you want to grab one of these as a kit from our store, head on over there with this link.
Build
We can't wait to see you put one of these together, so we're releasing the build video right now along with the release of the kit. Free plans for this model are coming soon!
Before you know it, you'll have an FT Edge in the sky. Be sure to share your experience with us through the FT Forums, Facebook page or by writing an article of your own. We'd love to hear about all of the crazy flights you have with these airplanes!
Order your own FT Edge speed build kit today!
Download the Free Plans on our Forum: http://bit.ly/2MmD4fD
Helpful Resources!
3D printed wing tips and landing gear fairings
Article by James Whomsley
Editor of FliteTest.com
Andres' design is clever, innovative, and easy to build. Yes there are more pieces, but they all fit together so smoothly and seamlessly.
This is a new direction in the design/build process that FT should espouse.
I’m kind of hesitant of not putting a spar richt down the middle of both winghalves, was this left out on purpose?
Thanks guys; love the way you are all keeping the hobby affordable and fun👍
In all the other designs and planes i have owned they put a rod or piece of wood connecting the wings to minimize the chance of the wings just snapping in half. There doesnt seem to nee one here; thats what seems strange to me..
It is however remarkable how many just dont put in 5 minutes to actually read.. sad really
I would like to give a challenge to the team to consider on a possibility to extend the WingSpan to 55” - 65” running under 4S or 6S LiPo battery, which a bigger Plane will be able to fight the windy weather better as well as a more stable flight.
FliteTest team has entered into a new phase of development and it will be a breakthrough if the FT Edge WingSpan can be extended.
Keep up the great job !
(For reference: the BEC used in the build video at time = 24:00 minutes)
in this video you can see that they were painted (airbrushed?)
Thanks for making this community AWESOME! and pushing the envelope of DT foam board planes!
I have been refreshing about 100x daily to see if the link is posted, can't wait to get started on this one!
Thanks!
https://forum.flitetest.com/index.php?threads/sp0nz-plans-index.17136/
Edge looks and looks to fly amazing! Great work Andres!
What is the span? I am considering building a 130% or maybe 150% scaled up variant from 6mm Depron with Either tape or film covering; It would most likely have even lower wing loading. The motorized 130% Depron FT planes I've built so far (Spit, Mustang) have been able to fly just fine with the same size motor setup as your 100% ones, as they basically had about the same AUW with almost twice the area. If a, say, 150% one would fit within a 2x2m box size, it might be just the thing for a really affordable aerobatic entry class. The local national F3A competition board is currently cooking up something like that, to try and get more people interested in the sport. Same principle goes for 3D, of course. Not all are equally fond of competing, but I've found to be great for learning fast, even if you finish last most times, as you learn from your opponent's advice as well as from taking more chances on doing unknown stuff than you usually would, and the prep for a competition gives for a good "push" on learning new skills and setting time aside for it........
Oh, and the idea of also offering the DXF files? Big 1+ from over here!
Any ETA on the plans?
when enlarging it with the acrobat reader, the folding space from 5mm to 7.5mm is also extended. Is there any way to fix it?
Thank you for this special plan !!!!! And thanks in advance for your answers.
