Scratch built using DT foam and parts from LazerToyz. The twin boom design of the P-38 made this build a little more difficult as compared to the other swappable style kits supplied by Flitetest. I choice not to build this aircraft as a swappable kit; however I used many of the same techniques in design and construction. This P-38 is running on two EMAX Power 28-22s and two 25amp ESCs. I fly is on a 2200 3s pack and get about 8 minutes of flight time. I chose to run this plane as a bank and yank (meaning no rudder control) and that seams to work great. As you can see in the video she tracks straight even in about a 15mph wind. I used the same type of under camber on the wing tips as used on the FT Spitfire. This means tip stalls are no longer a worry. The top speed is very respectable however, I used cut down 10x4.5 slow fly counter-rotating props left over from a past quad copter build. I would not recommend cutting down props but in this case it worked for me. Using 8x4 or 8x6 props instead would increase the speed and efficiency.
you wouldn't happen to have plans or a more detailed build description
great job
I'd like to built one.
