FT Old Speedster Twin 14 Gram Turnigy 287 Grams no battery 367g take off weight. 6mm Depron tape covered. Wing and tail as JB's plans size and location/relative position different fuse design. Aft mounted micro servos less than half the weight of two HXT900's Two Turnigy C1822 motors, nice wee motors well made.
Two 3.7 Gram servos on short linkages decent weight saving over two 9 G units
Voltage: 3~6v
Torque: 11.1oz / .5kg @ 6v
Speed: .12 s/60deg @ 6v
Weight: 3.7g
2.5 degree down angle on the motors much like the JB plans
Contra rotating props just down 8 X 4.7's around 6" diameter. Thrust 200 Grams @ 7.5 Amps on a 3 C Turnigy Nano Tech 850mAh
Specifications.
Diameter: 18mm
Length: 23mm
Shaft: 4mm
Weight: 14g (with 10cm wire)
Power: 50W
Turns: 20
Kv: 2100rpm/v
Resistance: 453
Idle Current: .2A
Max amp: 10A (15sec burst)
Voltage: 2-4cell Lipoly
Diameter: 18mm
Length: 23mm
Shaft: 4mm
Power: 50W
Turns: 20
Kv: 2100rpm/v
Resistance: 453
Idle Current: .2A
