I had been planning to make a ft scratch build but here in India foam board is not readily available. So after searching my locality the best building material I could find which would be suitable for FT plans was coroplast sheet. It is generally used for advertisements and has good retention for spray paint. It's made out of plastic and ca glue is one of the best options.
It is painted using grey spray paint.
The canopy made using soda bottle and thick paper
Thank you for reading!
But yeah it is stronger and cheaper than foam board and also a little heavier
