SPECS
- WEIGHT: (w/o battery) 4.1 oz (166 g)
- CG: 7.25 in (184 mm) from nose
- THROWS: 12° - 16° deflection; 30% expo
- WINGSPAN: 14.5 in (368 mm)
- *MOTOR: 2200 kv 250 size motor
- *PROP: 5 x 4 minimum
- *ESC: 12 amp minimum
- *BATTERY: 500 mAH
The final 2nd generaton FT Pun Jet! Changes included angled in vertical stabilizers, closer center thrust line, slimmer canopy and a host of other minor changes.
Even with a Mobius and streamers, the FT Pun Jet performs fairly well with the added weight and drag.
Here are two first generation designs.
Alex's extreme multirotor skills caught up to this one for an extreme closeup!
Tree!
A rear shot of the rocket assisted Punjet being loaded up! You can even see a little bit of the ignitor setup from this angle.
For the first launch we used a C-6 motor.
Loaded up for its sketchy rocket flight!
Hello!
Goodbye!
Desending into madness. Moments later the radio disconnected and the plane plummeted in!
That'll buff out....
Round 2. FLIGHT!
Not much wiggle room.
Successful ignition!
Once we knew that it worked, to no ones surprise, we had to go bigger! Next up with the C-11 rocket motor.
Such thrust... very fire... how rocket.... Wow...
Almost a successfull boost. The strength of the motor was a little too much for the FT Pun Jet. It re-folded the wings in a spectacular spiral of spinning s-nonsense.
Formation flying is always PUN!!!!
You asked for it and now it can be yours! We will be releasing free build plans with the build video on Wednesday, or you can get your Speed Build Kit from the store right now!
We love to hear your feed back and what you want to see from us. It's what helps keep us going. Make sure to post your build and mods in the forums!
What you've got there is essentially the FT Goblin... I used to work for McDonnell Douglas, so I have a soft spot in my heart for this little guy:
http://en.wikipedia.org/wiki/McDonnell_XF-85_Goblin
Gryf
damig
http://www.hobbyking.com/hobbyking/store/__8932__Turnigy_2200mAh_3S_20C_Lipo_Pack.html
