Introducing the FT Spear, the newest member of the FT plane family!
The FT Spear was designed to be able to carry all your gear when you fly, including FPV gear, two batteries, and even a vector system.
This wing is a mashup of the blunt nose Versa Wing and the FT arrow. It includes a large compartment reinforced with a center spar and ample room for all your electronics.
The Spear is made from four sheets of foam board and common materials, and it can be built in less than three hours.
Let us know what you think of the new FT Spear, and special thanks to community member Rüdiger for coming up with the name!”
SPECS:
WEIGHT WITHOUT BATTERY: 1.45 lbs (658 g)
CENTER OF GRAVITY: 3 – 3.5” (76 – 89 mm) in front of firewall
CONTROL SURFACE THROWS: 16 ̊ deflection – Expo 30%
WINGSPAN: 41 inches (1041 mm)
RECOMMENDED MOTORS: 425 sized 1200 kv minimum
RECOMMENDED PROP: 9 x 6 prop
RECOMMENDED ESC: 30 amp minimum
RECOMMENDED BATTERY: 2200 mAH 3s minimum
RECOMMENDED SERVOS: (2) 9 gram servos
I only wish the guys had not switched gears on us and used the much less common Graupner flight controller. :(. Frankly I'd love to see a few episodes highlighting this new design but dive deeper into using a naze 32 with fixed wing flight. With the general lack of info out there regarding Naze 32 and fixed wings, I'm sure a lot of us around here would find it an interesting and useful topic!
Looking forward to the build plans and video..I am also looking for something to try assisted flight but going to use APM with GPS for testing a long range setup. What kind of flight times is the spear getting?
I like wings, and this one looks like the best one yet. The design and work you guys put into this is top-notch! I would also like to see what can be done using a naze 32. I know the flying wing software has really improved since I first started working with it, maybe by now it's easy and reliable enough for most folks to incorporate into their build. I'm hopeful the quadcraze will settle down a bit and alow for development in other areas like wings.
Thanks for a great video, but now I'm starving... and it's not even 7a.m. If I order now, think I can get delivery by lunchtime? C'mon, Burrito Bomber!!
And now like to ask you a drawing of the Lance, I really like it. If I may?
http://www.thejay.com/wp-content/britneyspearsumbrella1.jpg
where will i find the build plans
thanks
Rushdi
:-D
