this is my design for the ft spitfire landing gear mod feel free to copy
this is the gear,make shure if you attempt this to mesure and sand, cut a relife channel so the zip ties are down and the wood will meet flush.
this is the tailwheel,put it flat and hot glue it. correction! you can not mount the tail wheel on top! also put packing tape before hot gluing!
this is the ft spitfire (not complete)
this is where you will have your gear glued to
feel free to copy!
"when life knocks you down try to land on your back,because if you can look up you can get up" -les brown
aka: if at first you dont succeed try try again
look for the next article when we finnish the build
