Spitfire Wingbox Repair and Upgrade
by hursto75 | May 14, 2014 | (6) Posted in How To
After flying my Flitetest spitfire and my BF-109 (basically the same fuselage), I found my front wingbox getting really weak and started tearing out. So  I repaired it multiple times with hot glue but it kept getting weak.
So I designed a reinforced wingbox that easily mounts in place of the foam wing supports. Built out of 1/8in birch plywood it should be strong without adding to much weight.
Wingbox It works great and you can still access the power pod. Now there is no reason to cut a whole new fuselage when your wingbox weakens. I have created an easy to follow how to video.
This mod can be installed during initial build of the FT Spitfire.The kit is also available for the BF-109 variant of the design. Here is a how to video.
The Plans or Pre-cut kits are available at the Attitude RC Store.
hursto75 on July 28, 2014
Just lowered the price on them to $4.00 at the store at http://attituderc.com/store.
Thanks
skyrod30 on July 28, 2014
That's a great idea, that should really save a lot of planes in one of the weakest areas. Thanks for sharing.
LordVader on July 2, 2014
Very nice and well worth the effort. Will be using these, I will use lite ply like I use for the motor mounts. Great idea, thanks for sharing.
