FTScratchBuild
FT SPORTSTER SPECS
- Weight without battery: 0.95 lb (430 g)
- Center of Gravity: 2.5 in (63 mm) from leading edge of wing
- Control Surface Throws: 12 - 16° deflection; Expo 30 %
- Wingspan: 39 in (990 mm)
- Recommended Motor: 1000 kV Park 425
- Recommended Prop: 10 x 4.7 slow fly
- Recommended ESC: 30 amp minimum
- Recommended battery: 2200 mAh 3S
- Recommended Servos: (x4) 9 gram
FT SPORTSTER PLANS
If you've never built our Swappable Power Pod, check out the video below.
STORE LINKS
New to the R/C hobby?
Here's some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get Some Here!
