My Trainer Build (FT Swappable Trainer design by smit6089)
This my first ever attempt at an RC plane; I'm just starting out and wanted to build something I wouldn't cry over when crashing it. It weighs in at 639g (flying weight), not sure if that's heavy or not; it's made from the UK foam board from HobbyCraft.
I've not flown it yet, but any day now, weather dependant! I also made a Versa Wing and will create an article for that too
The finished thing:
Two wings: Dihedral (top), and flat with ailerons (bottom)
I would buy slightly bigger guage than 18 next time; it's a bit too bendy!
A scalpul/Exacto-Knife makes all the difference!
I've also built a Versa Wing (flown neither of them yet!)
Dihedral wing
Flat wing, with ailerons (and programmed as flapperons!)
Wire strengthening for elevator:
Power Pod fitted:
I made a 12V power supply for my Turnigy Accucel 6 out of an old PC power supply:
I bought control horns, but in hindsight would use popsicle sticks (or the Flite-test ply horns) in future; way easier to use and structurally more sound.
Yep, only after I put the red tape on did I remember that port is on the left! Doh!
9XR with OpenTX, Turnigy 2200 battery, Hobbyking 30A UBEC, Turnigy NTM 2826 1100KV motor, FrSky X8R and matching module:
Prop balanced with tape. Notice the change in motor. The NTM had the prop shaft out of the wrong end, so I couldn't fit a prop saver, so I got this Turnigy D2826-10 1400kv motor, balanced with a bit of black electrical tape as you can see. I balanced it with the zip tie method.
PORT wine is RED & There's no PORT LEFT in the bottle PORT-RED-LEFT
Apparently sailors are famous for drinking Port wine!
The only possible negative I can see with the design is the tail-steering. All the landing forces transmit through the tail wheel and into the rudder's paper hinge (though I do see a clear tape reinforcement on your build). I'd be interested to hear how others have found this working over time? Has it been strong enough or has the rudder hinge needed patching? Also balance - does it need a lot of extra nose weight to balance out the wheel and wire assembly stuck on the tail? It's got a good length of nose, so it's probably fine - but I'm curious to know.
I don't know where you are with your flying skills, so please don't be offended if I mention I don't see any side or down thrust on the motor mount. Can I suggest dialling-in a touch of right rudder, and/or a couple of clicks of right-roll on the ailerons to help compensate for torque roll when you go for the maiden.
It's a nice build though, I'm looking forward to seeing some flight footage. There was none in the original build article you linked to, though lots of people sang its praises, but I always like to see a plane in flight to get a good idea how it performs. Cheers.
I'm not sure how well the tail will hold up, however I put plenty of tape on so should be ok for a while, and if it fails I'll just tape it again.
Balance was fine, the 2200 battery was well up into the nose, about 1.5 inches from the firewall so a little room for adjustment.
Not offended at all; I'm abysmal. Have about 5 hrs or so on RC Desk Pilot so orientation is fine, but I'm all left, or all right, or all up, or all down at the moment... need to dial back my thumbs. I managed to keep my Versa Wing in the air (mostly), have a total of about 10 mins on that thing, and 2 minutes on this one. I have dialed in a bit of right and down on the transmitter and it flew level and straight (until I smashed it into the ground). I also saw photos of how someone had built that into the powerpod by modifying the angles on the power pod, so next build I'll do that I think.
I have yet to see what effect the 3 flapperon settings have to flight... maybe tomorrow, UK weather permitting.
Little word left, bigger word right. I came up with this when I was a young Marine recruit at Paris Island.I remember the DI shouting "Port side shower up..starboard side shine 'em up". Since they don't shine boots anymore, I guess that is a thing of the past.
Damage: fuselage bent and torn, elevator torn, rudder bent pretty badly (easily hotglued back together), propeller snapped, and worst of all I snapped off one of the antennas from my FrSky X8R receiver! Not sure whether to get a replacement, or just go with a new OrangeRX module and receiver; might be more cost effective in the long run if I keep breaking them!?
Tim.
