We want to thank you for your purchace of the FT VersaCopter! We hope this frame will grow with your interests in the hobby, wether it be racing, AP, or just fun flying. Today, Josh will show you how to assemble the race quad setup. Keep a look out for more setup videos featuring different addons in the future.
For this build, the electronics we will be using are from our Power Pack E. If you are using a different electronics setup, the build process is exactly the same.
The Delrin body gives space and functionality to grip carbon fiber booms, however, you can follow this build video and simply sandwich square dowels between the VersaCopter plates if you don't want to use carbon fiber.
Check out the instructional video below and have fun!
SUPPLEMENTAL VIDEOS
If you were to drill a hole, you would definitely want to use a grommet so the sharp edges do not to cut your wires and fry out electronics.
Note: This is not a tested theory. I do not have a VersaCopter as all of my money is tied up in our newborn fund. Hoping for a Christmas present...
Best Regards,
Sidney
I can only find a 2013 rev 3 manual.
http://www.abusemark.com/downloads/naze32_rev3.pdf
Best Regards,
Sidney
Anyway - the helpful bit
It seems like I am the only one with the problem of trying to use a GR-18 receiver 33579 connected to a Graupner MZ-24 transmitter. Here is how I managed to do it after 3 hours of utter confusion:
1. First of all you have to realise that unless you get the GR-18 pre-configured with copterfirmware you will search in vain for the multicopter settings that Josh goes through with his usual clarity and helpfulness on the MZ-12. The GR-18 can either have plane/heli firmware installed or multicopter firmware not both. You can change between them.
2. Get the installer software for Graupner and the driver for the USB interface and the copterfirmware for the GR-18. I used the links on here: http://www.logicrc.com/default.aspx?s=c:0,c:ZZ-Support,c:ZZ-GRHoTT,c:ZZ-GRFirmware.
3. Next install the new firmware on the GR-18.
4. Then follow Josh's tips for setting up the ESC's etc but just be aware that when you are trying to move through the menus as Josh does with the right arrow, you have to use the soft "Ent" key on the screen of the MZ-24.
5. Good luck! I will let you know if mine works as soon as the current bad weather passes - could be next year...
Thanks to all the team! They got me into this hobby single handedly 12 months ago and I am now a complete addict.
Tim
Exmoor, UK
Let me know how you get on. Skibum315 - did you get anywhere?
