Ever wondered how to get your Glider into the air without having to use a high start or have buddy to run with a string? Well do you have a RC car. All you have to do is tie a kite string to the string and put the other end in your glider, and walah You have a glider tow. You may want to weigh the back end of your car down so it does not take flight.
But with a sure-fire way to get the glider up, you'll get lots of practice time. Well done for some outside the box thinking
Actually this wasn´t a tow! It´s a highstart. put a little Hook on the bottom of the sailplane at about 1cm infront of the CG then it will make more height and the car won´t try to pull the plane to the ground!
Try it out and happy flying
