Which Gremlin micro quad is for you?
When it comes to getting yourself a sweet flying, easy to assemble, super fun FPV micro quad to blast about indoors and out, we have got you covered. We have all sorts of customizable Gremlin components to build a standard Gremlin Micro Quad or our pro-level Turbo Gremlin. Here's an article to help you decide which Gremlin to get.
Standard Gremlin
Your standard Gremlin, when assembled using Power Pack G, comes with full speed RC stack. This runs on 2 cell power but, when using the included 2.3” propellers, you'll have plenty of power for both indoor and outdoor flying.
The Gremlin is designed to run the FX805 all in one camera. This 25mw setup is perfectly adequate for the shorter ranges you'll be flying with the Gremlin. To give you a clearer idea, you can expect to penetrate through walls and fly the length of a football pitch without too much breakup.
Is this the standard Gremlin for you?
These little guys are more designed for fun! If you're wanting a solid micro quad with the potential to thrill you indoors and outdoors, grab one of these. If you're wanting something with a little more of the beans, you may want to read up on theTurbo edition.
Turbo Gremlin
Meet the Turbo Gremlin. It's the bigger bro of the standard original Gremlin packed with more power and, quite simply, more excitement.
Under the hood of the Turbo is a bigger 20x20 mounting Stack. This is supplied when you order a Turbo Power Pack.
The HGLRC XJB F428 stack can handle more power too, meaning it can run 2s-4s. This supplies the bigger 1106-6000kv Gremlin motors with far more power that enables it to fly way, way faster.
You can also fit up to 3” propellers, although powerpack G comes with 2.5” propellers to get you started. If you want an easy way to upgrade, though, switching up your props is a great shout.
The Turbo Powerpack has a better video transmitter than the standard Gremlin. It's has a switchable 25mw-350mw micro transmitter which means you can fly further with more confidence.
Is the Turbo Gremlin for you?
Can keep up with bigger drones in speed designed for outdoors. Turbo Powerpack comes with bigger motors Gremlin 1106-6000kv. Higher performance all around.
Order Today on the Flite Test Store
Get flying and have a blast with either one of this fantastic micro quads!
If you found this article helpful, make sure to give it a thumbs up so others can find it too!
Share what you’re working on!
Write an article for Flite Test
Share on the Flite Test Fans Facebooks Group
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
https://store.flitetest.com/flite-test-power-pack-g-v2-flt-3050/p873728
the frame is available here:
https://store.flitetest.com/flite-test-gremlin-sidewinder-turbo-drone-frame-flt-1504/p739876
you will have to purchase the camera of your choice seperately, however
