Home made Delta Wing, based on Schraut5 XL type: 1 sheet of foamboard 1000x700x5mm (foam covered with paper) and one sheet of weak foam (normally used for isolation in construction) 10mm wide.
It has three layers: main one of foamboard, midle layer weak foam and top layer of foamboard, resulting a delta wing of 20mm wide.
Motor mount: Two plates of aluminium 1mm, screwed between them. One of them is "L" shape for motor mount. I also inserted one aluminium plate in the nose for protection.
Total weigth 680gr
28cm root chord.
20cm tip chord
5cm elevon
Motor: Turnigy D2836/8 1100KV Brushless Outrunner Motor
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=18969&aff=1070838
Prop: 2 tested ok 8x4 and 10x4SF
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22446&aff=1070838
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22425&aff=1070838
ESC: 40 A
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=24562&aff=1070838
Transmitter: Taranis-> http://www.alofthobbies.com/frsky-taranis.html
Receiver: Frsky D4RII->http://www.alofthobbies.com/frsky-d4r-ii.html
Battery: 2200 mAh 11.1V 3S lipo
Servos: HXT900 9g / 1.6kg / .12sec Micro Servo http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=662&aff=1070838
Atached->Plans I used to fit the schraut5 wing in only one sheet of 100x70 foamboard.
Big Thanks to Schraut5!!! for sharing his design
http://flitetest.com/articles/Scratch_Delta_Wing_Design
No Comments Yet
Be the first to leave one!
