We test flew the new Horizon Hobby Champ S+ plane, which is now available in the Flite Test Store!
The Champ S+ is super easy to set up, anc includes lots of great smart features such as SAFE technology, AutoLand, holding pattern, virtual fence, flight evelope protection and AS3X stabilization to combat turbulence.
AutoLand makes the Champ S+ autonomously land near the takeoff point using a stabilized approach. Holding pattern is a loiter feature that keeps the plane circling at a constant altitude until the command is canceled.
The virtual fence is a geofencing feature that creates a boundary that the plane will not fly past. The flight envelope protection uses pitch and roll limits to prevent the plane from entering extreme flight conditions.
The Champ S+ comes ready to fly, and it has a built-in direct hookup for FPV. Just plug in your camera and go!
The auto features are great for beginners but can be turned off as you get more experience, making the Champ a versatile plane for beginner and intermediate pilots.
The Champ is lightweight and flies nice and smoothly. We had a great time flying it together!
SPECS:
- Wingspan: 27.3" (694mm)
- Overall Length: 18.2" (462mm)
- Flying Weight: 3.7oz (105g)
- Motor Size: 180 brushless
- Radio: Included
- Servos: Included
- Prop Size: 5 x 2.75
- Wing Area: 114.5 sq in (738.8 sq cm)
- Speed Control: Included
- Recommended Battery: 7.4V 280mAh 2S
- Landing Gear: Yes
- CG (center of gravity): 1.1-1.4 in. (29-35mm) back from the leading edge
FEATURES:
- Exclusive SAFE® Plus drone technology from Horizon Hobby
- 3 flight modes: Beginner, Intermediate and Experienced
- Innovative AutoLand technology lands the airplane by itself.
- With Panic Recovery, stable flight is resumed by simply releasing the sticks.
- Holding Pattern allows you to pause your flight with the push of a button.
- Virtual Fence keeps you from flying too far away.
- Durable and lightweight construction so no FAA registration is required
- FPV ready using the compatible camera and headset or monitor (sold separately)
- 280mAh 2S 7.4V 30C LiPo battery providing up to 12+ minutes of flying time
- Powerful 2S brushless power system
- Everything you need is in the box!
Just as Josh Scott says "Over by the building".
Time was 6 minutes 24 seconds.
Robin, late in Texas I see! Sorry for posting it everywhere but where you instructed...
Keep up the great Job Guys!
