In this video, I go through the steps I used to flash a cheap Hobby King 20 amp ESC with the simonk firmware. The simonk firmware is a must to get the most out of your multirotor! I like them as they are cheap (but don't come with any bullet connectors) and have awesome performance after they are flashed.
The video goes through the whole process from what firmware to use and how to make the pins/cable to connect to the computer.
Search for "USBasp Programmer" on google or ebay for the usb programmer/cable required to do the flashing.
This is the command line I used for the flashing:
avrdude -c usbasp -p m8 -U flash:w:bs_nfet.hex
Below are the links I mention in the video:
The thread where I learned how to do it:
http://www.rcgroups.com/forums/showthread.php?t=1513678
The hithub links for the simonk firmware:
https://github.com/sim-/tgy
https://github.com/sim-/tgy/downloads
Winavr software:
http://sourceforge.net/projects/winavr/
The programming pads on the ESC
See the video for how to make the wire to interface with the programming pads.
The AVR USB Programmer
The homemade programming pins, made from some Cat5 Networking wire, you can use any wire but it should be wire that is stiff. You can see I used a blob of hot glue to hold it together.
My website: http://eclectic-workshop.weebly.com/
http://fly.gt6.ca/gallery/DW-Tricopter/0516-Build-Up/slides/IMG_5251.JPG
One problem you may have had is many times the programming pads have a thin, clear lacquer-like coating on the pads. Take a flat micro screwdriver and lightly scrape the pads to expose fresh copper, or in some cases, a fresh film of solder.
In the end it took 10 mins to put solder them onto the boards.
So I'm happy with my results.
just a little tip:
There is a simple flashing tool from lazyzero:
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
You can see an example on this page (not mine)
http://static2.fotoalbum.ee/fotoalbum/387/485/096992627bcb9a.jpg
