First, strip the wires on the battery plug about 1/4 inch. Strip the reciever plug about 1/2 inch. You can use the extra plug for a Turnigy Accucel 6 for this if you have one.
Pull back the shield on the reciever plug. Strip the insulated wire about 1/4 inch. The insulated wire is the positive.
Put heat shrink on and fray out the positive wires. Then push them together and twist them.
Now you can solder. Let it cool down and then test to make sure you don't have a cold solder joint.
Move your heat shrink down and shrink it.
Repeat the process with the negitive leades.
Test to make sure it works and have fun flying FPV. I hope this helped!
No Comments Yet
Be the first to leave one!
