PLEASE WATCH VIDEO FIRST.
Hello flite test fans, today I’m going to be showing you a cheap and easy to make way to make some gates for your fpv racing!
This is going to be a really quick video showing you what I did to make some fpv racing gates for indoor and outdoor RC flying, you can also change the sizes of the gates to suite your multi-rotor size or if you plan on flying with a bigger group of people.
I used:
-2x 2m x 2.15mm PVC waste pipe.
- 2x 90 degree 2.15mm waste pipe adapters.
- 2x 3 way 2.15mm waste pipe adapters.
I started by cutting the pipes down from 2m long to 1m. Leaving me with 2 75cm pieces of pipe and 2 1 meter pieces. . I then cut one of the 1m pieces into four quarters of 25cm.
At this stage you can glue the pipes together if you wish but I decided to leave the pieces friction fitted as it means I can take the gates apart and then assemble them at the flying field.
I got the three 1 meter pipes and attached them together using the 90 degree pieces to make a U shape.
I then attached two of the 25cm pipe pieces to the 3 way adapter and repeated this process for the other side to form the feet.
The simply attach these to the bottom of the U.
BAM.
You now have a cheap and strong gate for FPV races.
Thank you for reading my article, please subscribe to my YouTube channel and have a nice day!
