In this episode, Josh shows us how to program a 6 channel transmitter for differential thrust. Differential thrust is used for twin engine planes to give better yaw authority.
We programmed the Graupner MZ-12, which is a versatile and easy-to-use programmable transmitter.
To program differential thrust, you’ll need a 6 channel receiver and a 6 channel transmitter with at least four mixes.
On the GR-12L reciever Plug the left motor into channel 5 on your receiver and the right motor into channel 6. Do not plug anything into your throttle channel.
Make sure you remove your props before setting or testing and electronics!
On your transmitter, go to free mix.
Inside the free mix tab, program Mix 1 to potentiometer (throttle) for channel 5. Go down to Mix 2 and select potentiometer (throttle) for channel 6.
Set Mix 3 to rudder for channel 5, and move over one section to the right to assign the rudder to a switch. Press enter and push the desired switch to “On."
Set Mix 4 to rudder for channel 6, and move over one section to the right to assign the rudder to a switch. Press enter and push the same switch used in Mix 3 to “On.”
When you flip the switch on/off, you should see the on/off position for both Mix 3 and Mix 4 change simultaneously on the transmitter screen. If it’s backwards, reprogram it with the switch in the correct position. Both switches need to be programmed so they turn on/off simultaneously.
Go back to Mix 1 and scroll over to the verse/travel adjustment. Go to travel and change it to positive 100%. Press enter to save. This will allow channels 1 and 5 to operate under the same parameters.
Scroll down to Mix 2 and repeat the exact same process, so that channels 1, 5 and 6 are all using the same parameters and move together.
Program the travel for Mix 3 to negative 100%. If the transmitter says that the mix is off, flip the switch you program to the opposite position, and you will be able to program the travel.
Program the travel for Mix 4 to positive 100%. When you increase the throttle, 1, 5 and 6 should move in the same direction simultaneously.
5 and 6 will move opposite of each other, this is the best visualization of differential thrust.
Hook up your motors to test it out, make adjustments as necessary, and you’re ready to fly!
thanks
Charlie Spann
http://forum.flitetest.com/entry.php?507-Differential-Thrust-with-the-FlySky-Turnigy-i6
Since the Rud channel is your second motor channel I don't think you will want to mess with the Rud servo extents or your model will just fly in circles. I think you can just adjust the weight of Thr in the first mix and Rud in the second to tone down the effect. That's another disadvantage because you have two rates on different controls to adjust. Often Thr doesn't have a Rates switch to match the Rud. If Rud is the master to the two throttle CHs as in the "usual" solution then you can use the Rud rate switch to control both.
Some TXs have restrictions on what mixes are allowed with Thr. I don't think you can mix Rud->Thr on the DX6i for example, and since it only has 2 free mixes you can only do 1/2 diff (ie have the rudder affect one motor)
Not sure why the Thr CH is "moved" to CH5 for the Graupner. Probably there are some restrictions or behaviors on the normal Thr channel that are inconvenient.
Can I gut my Delta Ray and use the parts in a FT scratch build? I also have an old champ that I would like to try and use the components for a build. Any suggestions?
https://www.youtube.com/watch?v=O0GF5-IVhOA
I posted an article on it but I am awaiting approval.
I don't have digital plans for it yet but the center section of the wing is a 8" by 3 1/8" and the wingtips are 4" by 3 1/8". The horizontal stabilizer is 2" by 5". Finally the fuse length is 10". You can experiment with fuse designs, but if you watch the video it will give you a basic design of the fuse I used and had success with.
I have only made glider versions so far and I can't wait to make a powered version, if you do post a video of it on youtube. I'd love to see it!
