Some of the things i say In the video is rather confusing, please take a look at the specs below.
And feel free to mute. :P
A closer look inside my scratch build plane The Bobble Nose.
This plane was originally my first scratch built aircraft but has been upgraded quite a bit since the creation of v1.0. it's not a aerodynamic masterpeace but it actually flies alot better than it looks, allso at low speeds. Look under related articles too see more flight videos with The Bobble Nose.
"Den har aerodynamik, som en åben pølsevogn"
Plane Specs.
Wingspan. 1.4m
Length. 1m
weigth. 1,4kg.
Foamboard 5mm for wing and tail.
15mm x 15mm balsawood tailboom
packeging cardboard 8.5cm x 8.5cm squaretube fugelarge.
Plane Parts.
Motor: 2 x NTM Prop Drive 28-26 1000KV / 315W (short shaft version) original from my tricoptor.
Prop: 9:6 SF
Motor Battery: Zippy 3S 5000mah 20C
ESC: 2 x Multistar 30A opto
Servo:Turnigy 9g.
FPV.
GoPro 3 Black.
5.8ghz 1000mw tx BOSCAM w. clowerleaf.
2 x RX. 805 5.8ghz w. skewplaner and 7 turn helical.
EASY DIVERSITY.
A/V USB for PC (blackbox).
FatShark BASE SD video headset.
Car jumpstarter 12V power for groundstation.
Control.
AMP 2.5 w. UBLOX GPS
FPV / APM / servor Battery: Zippy 3S 2500mah 3C
UBEC: 3A 5V
Futaba T8FGs. w. RX. + 1W wifi booster.
- See more at: http://flitetest.com/articles/dangerdane-fpv-bobble-nose-v3-5-at-500m-altitude#sthash.CuHQ5G5A.dpuf
If you have any questions, feel free to ask them in the comments, I will try and answer them as soon as possible.
You want to know more?
Here is a video of the maiden of the early Bobble Nose v1.0. also my first YouTube video :D.
By
Christian J. Jeppesen
No Comments Yet
Be the first to leave one!
