Try the inverted Powerpod
In some cases, when you use the Powerpod, you get the Battery sticking out like a chinbeard.
Not so pretty.
What if I modify the Pod having the open side at the underside?
If you just use Barbeque Skewers for fastening, you may skip these steps. You can make your A-Folds as usual.
Just cut and fold.
Now there are Locks on both sides.
Above is a regular Powerpod.
Middle shows the additional cuts. (Paper partly removed)
Bottom is the inverted Pod. The holes for the locking Barbeque Skewer are to be repositioned.
And now the final test:
Where is the battery?
There it is!
Have fun
Werner
Naagar
