Special thanks to Audible.com for sponsoring this episode!
Flite Test viewers can download a free audio book here:
www.audible.com/flitetest
Josh and David had a chance to check out the Ka8 2.25M Sailplane PNP. Using a high start method they launch this glider and take it for a test flight.
Thanks for your support! Check out the other great videos mentioned in this epsiode!
Keep up doing this great work! :)
Now I gotta get a hi-start setup ... thanks guys! ;-p
I think Josh should eat more insects, it will get him fluent in German :) .
Thank you for the nice episode. Highstarts are too much hassle for me. I drove over to my rc shop in the netherlands (just 10Km away) and wanted to buy the Radian - but it was sold out. So I bought the last Radian Pro that was in the shop. Hopefully I am not disappointed after Davids strong words about it. From the first look it seems to be a very good kit but I will do some modifications to it.
1: Fit APM2.0 (with powermodule to power apm and frsky RX + minimosd)
2: Bought extra 2A BEC for the servos
3: Remove all magnets to NOT kill off the magnetometer (HMC5833)
4: Build some easy reachable adaptors for wingservos
5: Resolder/Shorten the motor esc leads. ESC will just power the motor.
6: Remove a little foam to make a fit for my bunch of 2200mAh 3S lipos.
7: Some clear Tape on the leading wing edges and on the bottom of the body.
So far the plan..... something is already done but it's my first glider build ever. Just flew a lot of Quadrocopter and a cessna (with combustion engine) in my youth (it was actually grounded because of it's 27MHZ Rc stuff going crazy when some CB guy started to talk on that frequency,,,)
Cheers Kraut Rob
Just wondered if the one in the K8 had any system like that?
Darren
